Coolant smell
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 19Jimmy87, May 15, 2002.
  1. 19Jimmy87
    19Jimmy87 Registered Member
    May 9, 2002
    65
    Kalamazoo, Michigan
    I am really new to the fullsize and older model 4x4. I need some ideas for why I am smelling this. I have had a flush and fill, the hose are good, no leaks. Why else could I be smelling this? Question #2-Is there any cheap way to brighten up the instrument cluster? All I have now is a faint orange glow. Also, I seen a pic of a cool fastback style soft top. Who has this, how much did it cost? Does it render the back seat inusable? Thank you all for being here.
  2. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    Your heater core is leaking. Check the passenger side floor for dampness. There is a write-up in the tech section on how to replace it.
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    If you are getting a coolant smell inside the cab. your heater core may have a small leak in it and may need to be repalced.
    Have you tried turning the light switch to the left. That should brighten up the insturment lights. If theyt dont work check the bulbs or maby a bad ground ?
  4. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Like they said, check your passenger side floor under the dash, it is probably wet from the heater core leaking. I just had this happen to mine...it's not TOO hard to replace and fix, just labor intensive and a very tight area to work in!
    As for your bulbs, you can replace them with new bulbs that are brighter - my brother just did this on his 89 Burb dash lights - I was very impressed with how much brighter they came out as compared to my stock 87 dash lights! Like your's, my dash lights give more of a "glow" than real light!
    Good luck!
  5. 19Jimmy87
    May 9, 2002
    65
    Kalamazoo, Michigan
    Thanks all. I will check into everything.
