coolant temp sensor location
Discussion in 'The Garage' started by georgiared84, Jul 14, 2003.
  1. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
    On all the other small blocks I've rebuilt the sensor has been between the 1/3 cylinders on the drivers side. Is there any problem putting it in the other head near the rear on the pass. side? I just put a set of heads on and that's the way they were on before. The plug on the driver's side doesn't want to budge.
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Should'nt be a problem. Most of the heat is near #7 and #8 cylinder's anyhow. /forums/images/graemlins/eek.gif
  3. georgiared84
    Sep 5, 2002
    487
    Austell, Georgia
    So if it ain't overheating back there it probably isn't overheating.
    /forums/images/graemlins/smile.gif
    I kind of figured temps would be highest there, but didn't know if the readings would be innacurate there.
  4. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Yep
