Coolant Usage
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudRebel350, Aug 20, 2000.
  1. MudRebel350
    MudRebel350 1/2 ton status
    May 20, 2000
    324
    N.J.
    I usually have to fill up my coolant every now and then, I'd say every month or so. Is this normal? Its not extremely low but its enough that I will notice a slight rise in temperature.
    JD
    88 Gmc Jimmy
  2. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    Do you have a overflow tank and is it hookedup? I had a slow leak in my overflow tank so when the fluid ran over to it-it was lost.
  3. MudRebel350
    May 20, 2000
    324
    N.J.
    I have an overflow tank and its hooked up and theres no spots in the driveway from that area. Sometime ill put a little coolant or water in the overflow and it will be gone real quick.
    JD
    88 Gmc Jimmy
  4. titanic
    Mar 27, 2000
    498
    You have to have a leak somewhere-pour some water in the overflow tank when the engine is cold and come back after a while and see if it's still there-if it is, check water pump weep hole after engine gets hot-it might be only leaking when you're going down the road.
  5. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Could also be pin holes in the radiator. Look for greenish color spot this indicates a leak. When the truck get hot most of it will evaporate. My 89 did this for a while till the bottom of the radiator finally roted out. But before that was leaking from water pump.
  6. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    You could also see if you can rent a pressure tester, from your local auto parts store. I know that we rent them at the Autozone that I work at. It is just a pump with a cap that replaces your radiator cap, and you pump up the pressure, and try to look for the leak. Good luck. - Steve
    Steve Sosa a.k.a. "sosaman"
    http://sosaman.home.texas.net/carpics.html
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    One last thing is does your K5 blow any white smoke when you drive it? You may have an internal leak that is small.
    Mike
    1982 GMC Jimmy - <font color=green>Emmett</font color=green>
    http://emmett.coloradok5.com
  8. Mine puffs a cloud or two of white smoke first thing in the AM when I start it. I have noticed I am losing a little coolant too. Are these related?
  9. Emmettology 101
    May 9, 2000
    8,126
    FL
    Could be you have a minor head gasket or intake leak that is letting coolant into your cylinders.
    Mike
  10. NYC K5
    NYC K5 1/2 ton status
    Apr 3, 2000
    185
    Staten Island NY/da bronx
    be careful i dont know if the blazer trany cooler is connected to the radiator but my friend just had a similar problem with his dodge. turned out coolant leaked into the trany fluid and did a good amout of damage. i have a manual we dont have that problem.
  11. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Check under the passenger side carpet after turning the heating on for a while. This will open the heater core for water circulation. If it's wet, your heater core may need to be changed.
    <font color=blue>//////
    http://blazer79.coloradok5.com
    </font color=blue>[​IMG]
  12. MudRebel350
    May 20, 2000
    324
    N.J.
    My truck only blows white smoke in the morning when its cold other than that it will never blow white smoke.
    JD
    88 Gmc Jimmy
