Coolant
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Adub, Oct 15, 2002.
  1. Adub
    Adub 1/2 ton status
    Aug 16, 2002
    106
    OK
    I replaced my coolant overflow and hose and it still leaks at the low point where the outlet is. Is there a trick to this? I bought the truck used, and you could tell that it has been leaking for a while, so Id like to get it stopped before it corrodes my fender well.
    AW
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    Take it out and look it over real good, might have a smal crack in the jug.
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I agree with outlaw- those tanks aren't that tough and I've had one crack in the exact same spot. If the tank IS good than maybe try putting a little RTV around where that hose goes on the tank.
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Are you sure that is where it's leaking?
    I had the rust on my inner fender and I noticed that it comes from the vent in the overflow tank, it turned out to be a bad cap that sent too much of the coolant to the tank and didn't let it go back when cold.
