COOLENT IN OIL
Discussion in '1982-Present GM Diesel' started by josephn, May 17, 2001.
  1. josephn
    josephn 1/2 ton status
    Nov 3, 2000
    138
    Utah
    I JUST REPLACED MY HEAD GASKET ON MY 6.2 DIESEL AND AFTER I HAD FINISHED I CHECKED THE OIL AND NOTICED IT WAS LOW SO I GO TO ADD OIL AND I SEE GREEN ANTI-FREEZE IN THE FILLER NECK.
    DO I HAVE TO REBUILD THE WHOLE ENGINE NOW OR SHOULD I JUST CHANGE THE OIL / COOLANT AND JUST RUN TILL IT DIES?
    IS THERE ANYTHING ELSE I CAN DO FOR IT?
    1982 6.2L Diesel K5 Blazer, TH700, 31 inch tires.
    Fire ALWAYS makes it better.
  2. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Change the oil. Buy, beg, borrow a radiator pressure tester. These can give you an indication if there is a real problem here (are you building extreme radiator pressure? - leaking head gsket). Possibly the coolant could have spilled out into the pan during the head removal/installation. You replaced the gasket, did you check the block/head for straightness? Did you replace the headbolts? (They should be, they're torque-to-yield bolts). When you pulled the head where there any cracks between the valves, common but can be repaired on the end cyclinders.
    Hey just think how fast you can pull the head, the second time around ;-o
  3. josephn
    Nov 3, 2000
    138
    Utah
    I checked the block and head for straightness, I also installed new head bolts too.
    If my old head gasket was leaking then it is a good thing i broke off that plug. Come to think of it my wife told me she was getting whitish smoke from it about a week or two ago.
    But I never noticed it.
    So now that it has coolant in the oil can i just change the oil a couple of times and then just run?
  4. DieselDan
    Jan 27, 2001
    1,056
    Vermont
    White smoke before? As in a dead glowplug on start up or continuous little wisps like steam? Check that radiator/cooloing system to see what's going on. If it is leaking it will continue so changing the oil won't fix it only prolong the inevitable.
