Cooling issues
Discussion in 'The Garage' started by rusty79beast, Aug 16, 2005.
  1. rusty79beast
    rusty79beast Registered Member
    Sep 30, 2002
    64
    Houghton, MI
    I have an intermittent cooling problem. It overheats only with the A/C on and running 75mph+. If going just 60 or so, it doesn't overheat. What could be the problem?? Clogged radiator, fan not working properly, thermostat, junk coolant???? The coolant was just replaced, and the system pressure tested OK. I've brought it to a few shops, but they can't find the problem! The outside temperature when this happens ranges from 75 on up. Also seems to like to overheat in heavy stop and go traffic. Anyone have any ideas or suggestions to check?? Thanks guys :bow:
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    On the stop and go, I would tell you to check the fan clutch. Mine went bad and caused that to hapen. As far as overheating at 75 mph I would guess radiator is cloged, but have no idea really.
  3. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    is it on ure blazer? is the inside of the rad look ok? no gunk u can see? i know its dumb but check front of rad to see if u picked up anything (plasic bag, rag, ect..)
    had girl come to me cause her car was overheating. her boyfriend put cardboard in front of rad to make it warmer for the winter. didnt take it out for summer :haha:
    pump? or possibly cap? it overheating on highway is strange. might be therstat not working properly.
    also tranny could do it if it isnt working right. my car is like that. same symptoms but i know its from towing to big of a trailer over to many passes.
  4. dyeager535
    26,979
    I have no idea what caused me to look this thread up again, as it's very old, but talk about a super time and money consuming problem that someone diagnosed fairly early in to the thread!
    Everything!
    Yeah, it's long, but re-reading the very first post, I see similarities with this problem. It's worth reading IMO. I'd be pissed if I did all that work only to find something that simple as the cause. (and I did, loose crank pulley noise gave me excuse to pull decent 350 and spend a lot more building another :))
    Besides, it's one of my most favorite threads ever.
