Cooling question Is it normal for...
Discussion in 'The Garage' started by Redfrog, Oct 15, 2004.
  1. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    Is it normal for a raditor to hot to the touch on top and cold on the bottom, and about 3/4 of the way up from to bottom be warm? When the engine temp gauge reads 200-210.
    If not any ideas whats wrong?
  2. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    That sounds normal , its working fine /forums/images/graemlins/waytogo.gif
    If the bottom was hot you would have a problem
  3. Redfrog
    May 4, 2001
    753
    IL
    cool, Thanks /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  4. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Sounds like some of the radiator might be plugged off to me? But I've never experienced this. /forums/images/graemlins/confused.gif
  5. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    I agree. The tubes go from side to side (silly design IMO). That means you can have a cool bottom (where crud collects) and a warm top.
    The top will be hotter in a functioning radiator, but I feel your's isn't functioning correctly.
    Why are side-side pipes silly? You should be able to pour hot water down at least 1 pipe so when it's REALLY cold out and your anti-freeze gels up, you can melt 1 tube. Then from there, the engine will clear the way just find it's self. I can't get water to pour sideways. /forums/images/graemlins/thumb.gif
