Cooling system stuff
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by '73 K5, Apr 8, 2001.
  1. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    2 summers ago when I had to replace my water pump I also put a new fan clutch on. One of the cheapo $21 Western Auto ones. Anyways I'm going to flush the radiator and try to get it ready for the upcoming summer...Should I replace the fan clutch now too? How long do they last? I'm just trying some preventative maintenance. TIA
    '73 K5
    Chevy good...Ford bad
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    There's really nothing to complicated inside the fan clutch- if it still works, I would just leave it. If you're really worried, buy a spare and throw it in the truck. FYI, my 84 still has the factory clutch...............
    <font color=red>PHOTO ALBUM-</font color=red> <A target="_blank" HREF=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</A>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  3. tRustyK5
    Jul 23, 2000
    36,178
    1,385
    E-town baby!
    My 81 still has the original too...one of the few original parts left[​IMG] Still works too.
    Rene
    [​IMG]<A target="_blank" HREF=http://jules.coloradok5.com>http://jules.coloradok5.com</A>
  4. dyeager535
    26,980
    You might want to replace it if its one of the ultra cheap fluid only clutches....The gm units were both thermo and viscous fluid units...yours should have a spring visible on the front of it..
    Dorian
  5. '73 K5
    1,763
    Kansas
    I just went out and looked and the front of it is just smooth. No spring at all. Does that mean I got one of the cheaper ones?
    '73 K5
  6. dyeager535
    26,980
    Yep, its a cheapy. The factory fan clutch works two ways...the fluid (viscuous) in the clutch body allows the fan to "stall" as air flowing over it reaches a point that the fan becomes a restriction, instead of pulling air, its blocking incoming air. (which is why stock clutch fans don't rob much horsepower) The spring on the front is to lock the fan when it reaches a certain temp.
    Most of my fans seem to come on about 200-205 degrees, and bring it down to about 190 before shutting off. All trucks probably got a HD fan clutch, (big) but only some of the cars got them, specificly ones with towing packages for example. Hotter the fluid gets, the less resistance it has...as the engine overheats, the fan would become less effective, instead of "locking" like a thermo fan would. I'd probably run it, but be real watchful of my temp gauge.
    Dorian
