Corp 10 bolt vs. Dana 44
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Mudder, Sep 3, 2000.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    When I bought my 8-lug axles as a set, I checked the gear ratios etc. but for some reason (heat stroke?) I thought the front was a 44. After I put it on and used my brain for half a second, I realized it is a corp 10 bolt. It is 3.73 with 28-spline inner axleshafts.
    Looking at my old 6-lug Dana44, the inner axleshaft had a pronounced "necked-down" area right by its 30 spline axleshaft. My 28-spline 10bolt axleshaft has a necked-down area also, but it is much less pronounced. Which axleshaft is stronger? A 30spline with a much larger neck-down or a 28-spline that does not have even half the neckdown?
    Is the difference in neck-down due to 1/2 ton vs. 3/4 ton or dana vs. gm?
    I have heard the two axles are about the same in strength overall. Will this 10bolt stand up to 36's on front? I know the 14bolt easily will.
    After all the bad mouthing i've done to 10bolts (on the rear) I get one on the front... ;) Karma?
    -- Mike '76
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I dont know about the shafts, but a Dana 44 and a 10 bolt are about equal in strength. The front axle is not semi floating so it is a little stronger than a rear 10 bolt. 35s are usually considered teh max for either one of these axles, and with mods 36.
    90K5
  3. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    well you may want to keep the 44 if it has the flat surface on the passenger knuckle. Those are selling for anywhere from 50-100 a set. They are what you need if you plan to do a cross over steering setup.
    As for the axles You can upgrade the axles themselves with the WARN chromemoly ones that ORD sells . I put them in mine and they do not have the neck down area. They were tested in a 4 wheel mag several months back and the axles were rated as strong as the the stock DANA 60 axle. Go figure. The u-joints are what failed and they will not bend the shaft. Since it is chromemoly. I also ran a good Spicer 5-297x ujoint.
