Corp 14 bolt wheel bearing snap ring removal question
Discussion in 'The Garage' started by Desert Rat, Feb 3, 2003.
  1. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I just pulled the hubs from my rear drums and removed everything but the larger race. It is held in by a large ring with two tabs on it. I have tried just about everythng to get it off from snap ring pliers (this isn't the usual snap ring w/ holes in it though) to a screwdriver, pliers, etc. No luck so far. The Chevy manual lists some kind of special tool to remove it. Even the local auto parts guru didn't have the right tool in stock. Any suggestion on getting this thing out? /forums/images/graemlins/angryfire.gif /forums/images/graemlins/1zhelp.gif
  2. jackedjimmy
    jackedjimmy 1/2 ton status
    May 18, 2002
    195
    Redmond WA
    I went and got some long handled snapring pliers andit worked perfectly. I've also gotten them with a long st of needle noes piers. Sometimes they can get kinda siezed in there so you may hve to hit it loose first. Good luck
  3. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    I used a pair of locking needle nose pliers and two screwdrivers. Grab the tang of the snap ring with the pliers, pull out enough to get the first screwdriver in. Start working your way around with the second, and then alternating while pulling up with the pliers. Just be carefull not to pull up too hard, or you will bend the snap ring. Mine might have been tough due to being exposed to the elements for a few yrs.
  4. djohnsn
    djohnsn 1/2 ton status
    327
    Plano, Texas
    I had the same problem with mine - ended up breaking one of the snap rings. The solution for me was to use a punch to move the race slightly away from the snap ring. After that, the ring came out easily.
  5. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    God bless Texas. I shoulda done that from the start. I feel like a booger eatin' moron. Worked like a charm. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
