Corp 14 rebuild/rear disk brake and hub questions
Discussion in 'The Garage' started by Desert Rat, Feb 3, 2003.
  1. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I plan on doing most of the rebuilding of my Corp14boltff myself. All but the ring/pinion. Question is, although I might be able to get the hub nut off using a punch, I'll just go and buy the socket for it. However, when I replace the bearings and races, should I bother getting the fancy tool that you use to drive them in and out? When I had my Bronco, I did the front D44 bearings and just used a punch to get them in and out. I was able to carefully drive the races back in and seat them without this wheel bearing puller/press that the Chevy manual recommends. Comments? Also, I will do the rear disk conversion while I am at it. I've been looking at the TSM, Shakerbuilt, and A-Tron kits. Anybody have any recommendations pro or con on these? /forums/images/graemlins/1zhelp.gif
  2. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    a punch will work good. Also helps to put the races in the freezer to shrink them a little bit., makes going in with a punch that much easier
  3. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I used a punch on mine and it worked fine, just be careful.
    As far as the disc swap, Ive got misfits brackets and theyre great! I bought TSM, but they are multiple pices and i didnt like the that. Too many pieces to worry about. I dont know about the others, but from my experience, Go with Misfits.
  4. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    I just installed the A-tron disk kit on my 14. Excellent quality, in fact it was about the easiest mod I've done to my truck yet.
    Rene
