Corp14ff rear disk conversion pics?
Discussion in 'The Garage' started by Desert Rat, Mar 31, 2004.
  1. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Looking to see how people have hooked up their rear brake lines when doing the rear disk conversion. I have the AZ-Kickin conversion kit installed, have the hose kit standing by to stand by, but don't have rear metal lines, at least that I can find so far. I'd like to see though how folks made the connection to the brakes if anyone has pics?
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Bent my own hardlines over, then used 12" braided AFCO lines and the adapter to the caliper.
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I made my own little bracket similar to Az-Kickin's and bolted it to the caliper mount. Ii used 78 K20 front lines.
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    Goodridge sells a real nice kit with a weld on tab
    do not have your line floating without the bulkhead connector
    I welded mine inboard of the spring perch as the stock style lines were quite long
    the Goodridge kit contains everything you need
    I think TSM pulls the label off and uses it as their hardware
  5. Highjaxx
    Highjaxx 1/2 ton status
    Apr 17, 2002
    273
    Austin,Texas
    I'm sorry for stealing the post! /forums/images/graemlins/ignore.gif
    I need a little direction, I just found out 15" rims WON'T fit over my caddy calipers. (yes, I did buy 8--lugs. /forums/images/graemlins/thumb.gif)
    So now that I have to buy new rims and tires in the next few days. /forums/images/graemlins/eek.gif /forums/images/graemlins/doah.gif
    What size do I need 16", 16 1/2", 17".
    I'm installing the D60 later, and now I don't want to shave anything off any calipers.
    I sorry again, but I figured you guys would have the most info on the subject. /forums/images/graemlins/thumb.gif
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Where did you get your disc brake brackets? What offset are your wheels? I had no problem clearing Caddy calipers with 15x10 wheels that have a 4.25 inch backspacing. They fit fine with TSM brackets and with my new AZ-Kickin' brackets.
  7. Highjaxx
    Apr 17, 2002
    273
    Austin,Texas
    The brackets I bought from another member, BUT thats not the problem. The rims where hitting the calipers just sitting on the rotors. I don't know what the deal is!
    If I ran 16" wheels could I run a D60 and the disc brakes in the back without trimming anything?
    I'm sorry again.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    16" wheels will fit anything Chevy has ever made.
  9. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Highjaxx, sorry to hear you are having trouble. I personally haven't had any experience with the caddy calipers so I'm afraid I can't be of any assistance. I know there are quite a few guys on here that are running them so maybe they can help you out. Good luck.
  10. Highjaxx
    Apr 17, 2002
    273
    Austin,Texas
    Thanks! /forums/images/graemlins/thumb.gif
    16's it is. /forums/images/graemlins/thumb.gif Chrome spinners. /forums/images/graemlins/thumb.gif Bling. /forums/images/graemlins/thumb.gif
    No more cheap, easy to find tires. /forums/images/graemlins/angryfire.gif /forums/images/graemlins/doah.gif
