Correct me if Im wrong
Discussion in 'The Garage' started by sandawgk5, Jan 23, 2007.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I ordered some exhaust hangers that are solid rod and I think they are 304 stainless. In order to weld these hangers to my aluminized exhuast that I am building I would need to us ER308L wire and it is OK to use 75/25 Ar/CO2.
    If this is the case can I do the aluminized pipe with the stainless wire also? Not really needed as I am going to paint it all black just curious.
    Ira
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    No need for stainless wire. You can weld the stainless just like regualr steel but it wont be rust proof like if you welded it with stainless wire.
    But since your going to paint it black it doesnt matter.
  3. sandawgk5
    Oct 28, 2003
    6,881
    I thought regular wire would not stick to the stainless base metal? If I can use regular wire that is a bonus as a 2# spool of ER308L is like $30:eek1:.
    Ira
  4. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I am in fact not a welding expert but I have welded stainless to normal steel and it has held just fine. It was a wheel well though so no real stress on it
  5. sandawgk5
    Oct 28, 2003
    6,881
    Well that is 2 that say just stick it. The weld in question would be 3/8" rod for exhaust hangers so no real stresses involved on the weld itself. I just remember as a kid I used the wrong rod when welding stainless and the filler did not stick at all it just fell off. Maybe with aluminized and stainless mixing together it holds.:dunno:.
    Anyone else?
    Ira
  6. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    Stainless to steel is fine with regular microwire. Welding the aluminized stuff is a pain unless you grind the area to be welded. So, figure out exactly where the weld is gonna be and grind that part of the exhaust tube and weld it up.
    Rene
  7. sandawgk5
    Oct 28, 2003
    6,881
    So run a flap disc on the area to weld to remove the aluminized and then regular 70s-6 will work?
    Do you have any knowledge of the millermatic 140? It has a new thing where you set the material type and size and the welder adjust automatically but you can still adjust manually. It is slightly more expensive than what I have my eye on and it does not come with a cart.
    Ira
  8. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    I haven't heard anything about the 140. The auto adjust might be really handy for someone that doesn't weld for a living as it'd get the machine into the sweet spot for what you're doing easily. Should save some headaches and farting around. That being said the MM 135 has a chart that will get you close quickly and easily too.
    Rene
  9. sandawgk5
    Oct 28, 2003
    6,881
    I think I am gonna stick with the 135 as it is tried and true. Is my logic on welding the stainless hangers correct?
    Ira
  10. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I have welded stainless hanger straps to 3" AL with no issues before.
    The only time I have broken one off was when the exhaust shop tried to braze the hanger to the back of my FLO40?????
  11. sandawgk5
    Oct 28, 2003
    6,881
    Cool, When you get back intown if you live down this way Stoody is the place to get your welding supplies. They beat Airgas and Westair by aboot $60 on a 50 CF cylinder with gas. And they have a military discount. I asked about welders and they told me where I could get a better deal than buying one with them. To me that says something about the company as a whole.
    Ira
  12. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    Sorry Ira, yeah just flap wheel the coating off the pipe and weld er up. I treat it the same as welding galvanized stuff.
    Rene
  13. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Most ideal filler for stainless to carbon is 309, but nearly anything will work.
