correct pinion angle for front
Discussion in 'The Garage' started by crazyhole812, Jan 30, 2006.
  1. crazyhole812
    crazyhole812 1/2 ton status
    Jul 6, 2005
    228
    missouri
    i did the 52" swap but didn't make note of the stock pinion angle. i'm sure that between the longer shackles and moving the hanger forward (= up slightly) the pinion is down a little. so what angle is it supposed to be? thanks guys
  2. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    There is no single correct pinion angle. What it needs to be is within 2 - 3 degrees ( opinion varies on this amount ) of the angle of the ouput on your transfercase. Google on pinion angle or driveline phasing, theres a ton of great info out there.
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I cranked mine way up to get the yoke out of the rocks. Mine does not see pavement though....
  4. goldwing2000
    goldwing2000 Guest
    If you have a CV front shaft, pinion angle is less important.
  5. clstolten
    clstolten 1/2 ton status
    Sep 4, 2002
    356
    With a cv the pinion should point directly at the cv, however the front axle has specific caster/camber built into it. If you want to rotate the axle, you will then have to rotate the ends of the axle/knuckles. I am curious as to what the stock angle is as well. I was thinking that if you dropped a plumb bob from the top balljoint, and then made a line from the top ball joint to the bottom balljoint, and set that angle to what it would have been stock. Should keep the caster/camber set correctly for good road manors. I need to figure out what this angle is, since I just swapped 52's as well. Anybody have that info?? Or maybe the correct way to get the factory settings back?
