Correct timing setting for a 1970 350 (9.1:1 w/ HEI)
Discussion in 'The Garage' started by BillyTungsten, Dec 4, 2005.
  1. BillyTungsten
    BillyTungsten Registered Member
    Jul 24, 2005
    63
    Minnesota
    Engine is running (after swap) but I get a wicked backfire coming off the throttle and overall power is lower than it should be. I bought a timing light yesterday, but have never timed an engine.
    Anyone know where I should be from TDC? Any other general advice on correct timing is also appreciated!
  2. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    need some more info from your end, what cam are you running, carbed or tbi or tpi, egr or not, I'll get back to you as soon as I see info :D
  3. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    I would start at 8 degrees BEFORE TDC, as a baseline. Don't forget to unhook and plug your vac advance line while setting the timing.
  4. BillyTungsten
    Jul 24, 2005
    63
    Minnesota
    more info & pics...
    The engine is from my 1973 blazer, PO told me it was a 1970 350. I do not believe the cam is anything but stock, as the PO had a pretty flowery list of anything that wasn't stock.
    It is carburated
    One of those hoses is the vac advance that I need to plug, right?
    Also, this is what the timing mark looks like...
    which is 'before' versus 'after' to the left of the mark or the right as I face the engine?
    Thanks! I am learning thanks to you guys!
  5. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    See the pot on the distributer under/behind the fuel inlet on the carb? That is the vacuum advance. Simply pull that hose off, and plug it.
    On the timing mark, to the right of 0 is the advance side, I do believe. (Been awhile)
    Although looking at it, I think the A stands for advance, and the R stands for retarded.... :confused:
  6. BillyTungsten
    Jul 24, 2005
    63
    Minnesota
    TTT...
    I am waiting for some info so I can get this done... I don't want to put the PS pump in until it is timed, so I am kind off hung up until someone helps with timing info.
  7. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Put that PS pump on there, you can still time it with it in place....
