Correct way to ground a k5
Discussion in 'The Garage' started by blazindorito, Sep 22, 2006.
  1. blazindorito
    blazindorito 1/2 ton status
    Nov 25, 2003
    2,047
    Southern California
    What is the correct way to ground the truck? I currently have battery to engine block, battery to frame. Is this correct or is there a better way? Thanks. I almost have no power to anything elecrical.
  2. badmix
    badmix 1/2 ton status
    Nov 7, 2004
    4,205
    60
    West Virginia
    There should be a ground from engine block to frame. And then batt to frame. This is the way mine is setup. I have a ground strap on pass. side and may for redunancy put one from engine to frame on drivers side. Cant have too many grounds.
  3. diesel4me
    Jul 24, 2003
    17,552
    939
    Massachussetts
    one more ground...maybe two..or three!
    Factory setup had a braided strap from one valve cover bolt to the firewall too...a few trucks had a similar strap screwed to the right cab mount,and went to the frame...some also had a strap grounding the tranny case there too...most of these get removed or broken,and left off..:crazy:
  4. Metrodps
    Metrodps Strange but nice guy Premium Member GMOTM Winner Author
    Jan 4, 2006
    9,726
    108
    earth
    There should be a ground wire going to the fender from the battery also. When you say almost no power to electrical what are you getting?
    Raining here now I will take picture if you need one. Mine is a 1987
  5. blazindorito
    Nov 25, 2003
    2,047
    Southern California
    What I mean by almost no power is all power windows go up fast but are really slow coming down. If I reverse the wires then it goes up really slow and comes down fast. The dome light looks like it's dim. My wiring is all screwed up plus I figure it's not really grounded right.
  6. Metrodps
    Jan 4, 2006
    9,726
    108
    earth
    What I would do is check ground points battery to fender, battery to frame, battery to motor. Then check to see if you have motor to cab fire wall.The windows do that some times due to contacts being dirty or corroded. Get some electric contact cleaner and spray the wire ends to the window motor.
    The tail gate is only grounded by the hinges and they rust causing it to lose ground. Some of the other guys out there can give you more details. My memory is not to sharp today so I am foggy on what you should get for reading on a voltmeter.
    Hope that helps you some on sorting it out. I am sure you know to be sure contact points are clean.
  7. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    Also check all your grounds. Take them off, clean really good with a wire brush and put back on. Even though it's grounded, over time they corrode and are not as effective.
