corrisive soap?
Discussion in 'The Lounge' started by surpip, May 14, 2006.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    so my soap pump stopped working, took it apart and the little ball bearing in there was corroded.
    fine
    a caster broke at home depot, spilled the bearings, i brought some home, turns out they are the same exact size i need.
    put one in and it works for a day, than it stops working again
    pissed
    take it apart, and its corroded, rusted real bad
    so they can handle grease and oil, but not soap?
    WTF?
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Soap does have a corrosive material in it, i have hauled some of the bulk material used as an additive in regular old soap, and it required the use of "corrosive" placards on the trailer.
    Not sure what you have going on there though,,,what kind of "soap"
  3. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    Anything with Citris in it will corrode. Citric acid that is in minute quantities. The bearings that you pick up probably were only steel and not stainless steel.
  4. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Centralia, Washington
    Not to mention if it had lye in it...
    Go with stainless.
  5. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    OK damn it this is border line tech sh!t, don't make Me hit the notify button.
  6. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    When I said stainless, I meant underwear. That cuts down on soap usage.
  7. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    just regualr anti bacterial cheapstuffatwallyworld soap
    where would i get stainless bearings?
    not sure if i want to put that much effort into my soappump
    even though it is pretty dang cool
    oh and corey
    kiss my ***
