Cost for reshafting front driveshaft?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Mudder, Sep 29, 2001.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    What's the going price to have a front driveshaft reshafted? It's a good 3" or so too short.
    Also, it would be pointless to balance it right? I don't think I've ever gone faster than 30 in 4wd.
    -- Mike
    <font color=blue> The mud's on it to hide that it's more than one color.[​IMG]
  2. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Should be less than $100. Wrong! It is critical to have the shaft balanced correctly. Bad vibrations can happen at very low speeds.
    Derf00
    "A WISE MONKEY NEVER MONKEYS WITH ANOTHER MONKEY'S MONKEY."
  3. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Around here it would cost you at least 110 bucks or so.
    45-50 per end to cut the old tube off plus cost of new tube.
    Then again, FL is more $$$ for all things mechanical.
    Still Poundin' "pavment" after 275 Posts!!!
  4. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i would say $100 or so. might what to think of stepping up to a stouter shaft. I learned the hard way with my 1/2 ton shaft. If u need a new one, go for the gusto
    -Zakk
    '77 K5 SB 400 TH350 NP203 p/t 6" Lift D60 14BFF 4.10's 36"Wrangler II's
  5. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    what did you replace it with?
    i am still running a spicer 913971-2600 based shaft
    1310 sagy style cv, but changed front yoke to a 1330
    only broke it once, my fault something HAD to give.
    -40deg, chains on, in reverse, high rpm, insane wheel hop, chained to a fully loaded, stuck in the ditch, cummins dodge extra cab, while winching with rear winch hooked to a tree.
  6. RedDwarf
    May 9, 2001
    816
    Now that's quality breakage!
  7. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    I ended up paying $130 for it. Retubed approx 2.5" longer, welded-on welch plug, and new needle bearing in Cv (not complete rebuild, just new bearing - some were missing from a previous bad install I did).
    I guess that's not too bad.
    I'll paint it tomorrow and put it on.
    -- Mike
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Only 30 mph in 4wd? What kind of offroading do you do? I had my tries spinning 115 MPH once!
    Tim
  9. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Maybe if my speedometer worked, I'd know how fast I was going in 4wd.
    In the mud, I've run the engine at redline in 2nd gear in 4 lo, 3.73 ratio and 33's. Makes a nice rooster tail. Dunno what the speedo would have read.
    -- Mike
