COST TO BORE ENGINE???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TB2Blazer, Jun 2, 2003.
  1. TB2Blazer
    TB2Blazer 1/2 ton status
    Apr 6, 2002
    166
    Cleveland, GA.
    I am planning on boring my engine over and was wondering how much should be done and also about how much it would cost.
  2. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Re: ENGINE QUESTION
    Why do you want to bore it again???? I'm getting the impression you are looking for more power....
  3. TB2Blazer
    Apr 6, 2002
    166
    Cleveland, GA.
    Re: ENGINE QUESTION
    I'm replacing the rings and pistons and all that jazz and rebuilding the heads so I figured I might as well bore it out a little while I'm doing everything else.
  4. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    Re: ENGINE QUESTION
    Just have it measured. If the bores aren't 'egged' or in bad shape, I would leave it be. If you decide to bore anyway, go with the smallest overbore possible. This will leave room for future rebuilds.
    Kinda depends on what you are after though.
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Re: ENGINE QUESTION
    boring it out doesn't gain you a whole heck of a lot in the power area. Sure it helps but like was said just bore it a little bit if you have to. If not I say just hone it and file fit some rings.
  6. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    funny how you ask a simple question...and people start asking why would you want to do that...if you wanted an opinion... would you have asked?
    sorry folks...that always drove me nuts.
    sorry i dont have a price for a machine job, guess im just as bad as everyone else.
    if you wanna go bore it out, do it.
  7. dyeager535
    26,975
    Typical cost is around $10/hole I think.
    Thicker cylinder walls are better for a daily driver, go with the smallest overbore you can. I think you can get .010 and .020 pistons for a SBC, so even if it can't clean up with a hone, at least you don't have to go real far with the overbore.
  8. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    Yep, same here. About 10 bucks a hole.
  9. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Re: ENGINE QUESTION
    Can't you get the walls sleeved the next time you rebuild?
  10. dyeager535
    26,975
    Re: ENGINE QUESTION
    Sleeving seems to be an unreliable science. It can be done, but the way I see it, trying to force an oversize sleeve into a bore that is already thin or damaged, is dangerous work.
    Not saying it shouldn't be done, but I've known people who have ruined blocks having them sleeved. It's a difficult process, not sure on the expense part. I bet it's not cheap. Probably cheaper to get a different block, at least with Chev's right now.
  11. Gary 86 K5
    Gary 86 K5 1/2 ton status
    Oct 7, 2002
    204
    Mentor, OH
    I paid $100 to have the block on my Camaro bored .030 over.
  12. 4DiggerDan
    4DiggerDan 1/2 ton status
    Feb 2, 2003
    103
    Montucky, USA
    We charge 160 for any V8 for a bore, hone, clean and remove and re-install all the plugs. At that rate we chamfer all the bolt holes bigger than 1/4-20 and chase all the threading too...
    .030" is the first oversize you'll find for a 350, .060" is the biggest you'll want to go. If you do re-ring it don't use anything but a cast ring. The proper way to hone a block is about 90% technique and craftsmanship and 10% witchcraft, black magic, and voodoo /forums/images/graemlins/grin.gif
    Oh yeah... Honing with a deck plate tacks on another 45 bucks since you've got to change stones twice as much.
  13. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    mine was $11 per cylinder, including bore, hone, plateau hone, and chamfer. I had a lot of carry-over cost with my build up since I had the works done to the block...
    Chris
