Could the old tranny cooler be the new P/S cooler?
Discussion in 'The Garage' started by pvfjr, Jul 18, 2004.
  1. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    When I converted from automatic to manual I obviously had no use for the tranny cooler, so it's been just sitting there. I was wondering, could I run the return line through that and back to my power steering pump? Will it do any good, or will it just make the fluid hotter since it's built into the radiator?
    Has anyone done this before? Or should I just get a seperate cooler and mount it up?
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    It will make a difference, but unless you are running hydro-assist you prolly won't notice it /forums/images/graemlins/waytogo.gif
  3. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    I'm pretty sure I need it, gotten pretty hot and foamy before. The only issue is whether the one built into the radiator will be cool enough, or if it will do more harm than good and I should get a separate one.
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    DO NOT use the cooler in the radiator. You want cold air not hot water.
  5. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    I suspected it might be too hot. Where's a good place to pick up an inexpensive cooler?
  6. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    UUUMMM, ya ever been to an auto parts store??? /forums/images/graemlins/dunno.gif
  7. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Here is what I did with mine. I got the cooler from my Brothers tranny he swapped out. Cleaned it real well, and installed. Really easy and it helps a lot. No more spilling over and no more pump whine when wheeling /forums/images/graemlins/thumb.gif
  8. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Ya ever seen different prices and different products at different stores??? /forums/images/graemlins/dunno.gif
  9. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Your best bet for really cheap would be to hit up your local wrecking yard and start looking at the older Ford cars and trucks, they used a small P/S cooler on some of them.
  10. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Thanks for the pics, seems fairly simple. Just hope I can find one real cheap.
  11. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    No problem, that's what we are here for. Make sure when you buy new hose it is power steering pump return line. I made the mistake of getting fuel line. It will detiorate with PS fluid going through after some time. Just a heads up. I got 4 ft of hose which will be plenty for ya /forums/images/graemlins/waytogo.gif
