Could this be a ball joint???
Discussion in 'Pacific Region' started by DuneRunner, Sep 11, 2002.
  1. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    Correct me if I'm wrong the ball joint is the pivoting pint where the axel and the steering knuckles attach? correct.
    For a while now I have been experiencing a nasty vibration up front on the drivers side. While at idle the front drivers tire vibrates shacking the whole truck. I have replaced the bearings, pads, got rotors turned and regressed everything. SO I looked under there today and saw that the lower joint is wet (like a leak of the seal) And well they are all original joints. Since 83.
    Now here is yet another question. To replace the joints do I need to take the axel off to get then pressed in or do I drive the truck in to a shop and let them do all the labor? And how much should I expect this to cost if I where to do all at once?
    What else could it be if its not this? The tires have been balanced not that long ago. Thanks for reading this... /forums/images/icons/frown.gif
  2. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Hey ditto that for me ken..I was going to try to do mine this weekend with a hand press that my brother has,I was told they were ok to do(that is the only thing I haven't changed in the front besides going to the rockrod) ....The Big O tires here in town wanted 400 bucks to do them and a alingment /forums/images/icons/shocked.gif /forums/images/icons/shocked.gif
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    You can remove the knukel and press out the joints from the knukel. I have a shop press you/we can use!
    Too test is your BJoints are worn, jack up one tire and with two hands put one on the top of the tire and one on hte bottom and try to move/rock the tire in and out. if the tire moves at all the joints are smoked!!!
    If you do replace them I recomend you spend a few dollors more and by Moog Brand Joints. Top quality American made!
    Let me know if you want to visit Me!!
  4. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    HA HA HA HA HA YA Right Like I can afford that. /forums/images/icons/blush.gif /forums/images/icons/mad.gif /forums/images/icons/confused.gif I just might see if my uncle can give me a hand. I think he has a press. What brand did you get? I'm going to start making a few calls around to see what every ones recomends. Thanks for the heads up /forums/images/icons/grin.gif
  5. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    Sounds like a plan. I'll shop around and find where I can pick them up. (NAPA Auto) more then likely. Let me know when a good date and time are for you. O ya I'll look into lifting the tire tonight or tomorrow. (mmmmm Coors Light) /forums/images/icons/grin.gif
  6. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Ken-
    When you jack up the truck make sure to isolate if it is the balljoint and not a wheel bearing... On mine after i took the rotor and spindle off i could still move the knuckle and see the play in the balljoint.
    Its a bit of a pain but yours aren't quite as old as my balljoints were. I think it'll take something like a 1 1/4" socket to unbolt the top nut and a 1 1/16" or 1 1/8" for the bottom after the cotter pin.
    After i unbolted the top and bottom nuts for the knuckle, then i had to get a big sledge and pound on it so the tapers would bust loose.
    I took the knuckles to a place next door to my work and had em pressed out and new balljoints pressed back in.
    The hardest part was pressing in and out the balljoints.. The dude with the press said he had a hell of a time getting em to budge. But there is a specific press tool for a Dana front end to to balljoints.
    There is also one other tool that i had to make for the camber bushing on the driverside.... I took a 3/4" socket and i ground at it with a dremol tool until it had the 4 prongs in the right locations you'll need. I still have that tool if ya need it.
  7. Burt4x4
    6,854
    I would guess the Napa brand should be good quality too. They don't ussually carry Moog thou, CarQuest auto stores do as well as some of the smaller ma &amp; pop auto stores. Just don't buy that cheep China crap. Sept. is booked for me already.
    Let me know what you decide to do...
  8. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    Burt–I'll do some shoping around and let you know.
    Ryan–I'm not sure if the 10 and the 44 are totaly different or not. I think that I would rather be safe then sorry. I'll PM you with my #. Thanks...
  9. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    I just got a quote for $650.00 to use Moog parts and he said it would take up to 5 hours. hhhmmm
  10. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Dang!!!!
    I think i got an estimate for like $300 if i brought him the parts and the whole front axle....
    I'd buy the parts, take the knuckles off and take em to a shop to have the new ones pressed in. Just that labor should be under $200 i would think!
    I don't have a lot of free time right now but i could probally give ya a hand if ya need sometime this weekend i might be in your neck of the woods.
  11. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
  12. Burt4x4
    6,854
    HolyMoly!!! F that!!
    Do what Ryan said. It should only be like 60bucks to have the joints removed and replaced if you bring in the bare knuckels. Heck maby the place you buy the joints at can doit?
    Or take your rig apart and come out to my place and we can doit on my 12ton floor press. I just don't have the time right now to tear your rig apart in my driveway. It would take a full day to tear down and put back together all in one shot. Maby in October???
    Good Luck Brother
  13. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Hey Ken, you must have forgot about me. I can get you a discount price on Moog ball joints which I believe are about $25.00 each and I can do the press work for $60.00 and I also have the spanner socket needed to preload the ball joints with. All you need to do bro is call me sometime. I think you are just about married or something. /forums/images/icons/laugh.gif /forums/images/icons/smirk.gif /forums/images/icons/grin.gif
  14. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    LOL...married whats that? /forums/images/icons/confused.gif
    NOT for a few more years. /forums/images/icons/tongue.gif
    I'll give ya a haller tomorrow at work. Scott Should I bring over the whole truck or just the nuckels?
    If I can do it for $160.00 or a few more here or there I'll do it. I know the last time I was at the shop and the guy came in with a Honda ball joint to be pressed it. It took like 20 mins. Thats COOL.
    Do I need any special tools to take off the knuckels?
    Thank you all for your help. /forums/images/icons/grin.gif
  15. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    BAH!! Ya'all are qa bunch of damn weeners!! /forums/images/icons/smile.gif Just go down to AutoZone, rent a ball joint press, and do it yourselves. Homo's! /forums/images/icons/grin.gif /forums/images/icons/laugh.gif /forums/images/icons/cool.gif
  16. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    YA YA YA...
    I actually took a good look at it this weekend and saw that it wasn't the ball joint, found the leak is comming from the axle.(drivers side seal) So I believe its the Motor mounts. That are causing the major vibes. (I hope) Off to buy new ones this afternoon.
    "the fun never ends" /forums/images/icons/frown.gif
  17. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    Ok the latest in this story.
    It seems to be a tire out of ballance. and most likely a motor mount or both. (I have 2 new polly urathan (sp) at home)
    I'll find out hopefully this weeken. /forums/images/icons/ooo.gif
  18. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    You know, that was the fix when my torque converter was going bad right before Blazerfest.
