Could this be the one?
Discussion in 'The Garage' started by 82_k5, Aug 28, 2005.
  1. 82_k5
    82_k5 Registered Member
    Oct 3, 2003
    94
    MY 10 bolt spiders blew up and I have been looking for a 10 or 14 bolt. I found a 1973 3/4 ton 4x4 with a 14 and a d44. It also has a 350/sm465/np205. It has been sitting for a long time and the body is rusted and beaten. Is it worth $400 and will those axles bolt up to my 82 blazer? I figure I can almost get that back out of it with the tranny/t-case. Thanks a lot.
  2. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    I would go for it.
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    465/205 and 14 bolt with 8 lug 44 def worth $400. I would think trans and transfer case would be worth that by itself.
    Ira
  4. 82_k5
    Oct 3, 2003
    94
    sweet, I think i'll go for it then. Anyone know if the axles will fit directly or how much mod. is needed to put them in an 82 k5?
  5. sandawgk5
    Oct 28, 2003
    6,881
    The only thing you have to do to make those axles fit is to get a conversion u-Joint. The 14FF is 1350 and your 10 bolt is 1310. I think there might be a caveote that if you have a 465/205 combo then the rear driveline is 1350 even if you have a 10 bolt. I am not sure about this I could be wrong.
    Ira
  6. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    I wouldn't go for it. Send me the contact info so I can buy it!!! :D
  7. sweetk30
    Nov 1, 2004
    25,554
    547
    horseheads , ny 14845
    that old a 44 will have a flat top knuckle on pass side . so then you will be half way to cross over steering kit.
  8. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    where are you located? i would be willing to take a motor off your hands... if you are close that is.
    Grant
  9. 82_k5
    Oct 3, 2003
    94
    tomorrow i'll pull off some covers and look at it, I'm in Boise ID so it might be a little far. If you wanted to come up here though I'm sure we could work something out, if I get it.
  10. 82_k5
    Oct 3, 2003
    94
    Anyone know what ratio those axles are most likely to be? Thanks
  11. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    4.10 most likely. There is a chance they are 4.56.
  12. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    I'll hop on with everyone else, get the thing... In my neck of the woods the t-case alone would pull $400 and the axle gears are probably gonna be 4.10
