could use some help
Discussion in 'Plains Region' started by aj_tatted, Jan 13, 2004.
  1. aj_tatted
    aj_tatted 1/2 ton status
    Sep 6, 2003
    183
    arlington, tx
    i bought wakeboard's axels from him, however the ring and pinion was never adjusted properly and now i'm getting alot of noise out of the diff. i have a brief understanding of how to shimm them but i have never done it before. is there anyone in the dfw area that could lend a hand?
  2. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    Sorry to hear you have having problem, but i did not ever hear any problems with it or any sloop. Let me know what I can do to help.
  3. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    Do the axles have detroits? If so they make a 'click click click' noise all the time when one wheel is spinning unlocked. What does the wear pattern look like on the gears? If you can't tell, get some gear marking grease and check the pattern before pulling stuff apart. There is a wealth of info on here and the net to help you determine if the gears are set up properly. I will also help with what I can.
  4. aj_tatted
    Sep 6, 2003
    183
    arlington, tx
    the noise only starts when i let off the accelerator.when no power is being applied to the gears.
    do you still think this could be the locker?
  5. Nonesuch
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    It sounds like the locker is disengaging. It is designed to unlock. This normally happens when one wheel is spinning faster than the other and there is no power being applied. Jack up both wheels and spin one of the tires forward and then quickly spin it backwards . The other one will free spin and you will here the Detroit going 'click, click, click'. I would put money on it that you are hearing the Detroit and not the gears. If you still want to inspect the gears I can help you with that.
  6. aj_tatted
    Sep 6, 2003
    183
    arlington, tx
    i am beginning to wonder myself, today i took it down to my local tranny shop, and on my way down there it didn't do it.
    could you give me a call? 817-465-7115 or 682-465-6402
    thnx, AJ /forums/images/graemlins/thumb.gif
  7. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    Any news let me know!
  8. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    That avitar is hilarious!! /forums/images/graemlins/rotfl.gif
  9. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    all good?
    just never heard back from you...
