Could you really squeeze a 43 gallon tank under a K5???
Discussion in 'The Garage' started by triger, May 29, 2003.
  1. triger
    triger 1/2 ton status
    Jan 16, 2003
    177
    Budd Lake, New Jersey
    <font color="green">I was surfing the web and found a 43 gal tank for K5's and was amazed you could even squeezee something like that under there... /forums/images/graemlins/shocked.gif has anyone ever done this? Would be nice to be able to hold that much gas for the long road trips out west...Not like I could ever afford it anyways but was curious... /forums/images/graemlins/confused.gif Welp back to looking for other useless things for my truck... /forums/images/graemlins/thumb.gif
    T </font>
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    lol i have that same problem, dont look at it as useless. but more like overkill ;P overkill rocks.
  3. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    Just think how low that thing would hang, waiting for its first taste of rock.
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    if you were to re locate a cross member or two you could do it. but only if the tank were narrow enough to fit between the frame rails. also it could sit lower. but not much.
    Grant
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Years ago I had a '72 Blazer. I was up playing in the Wasatch mountains, outside of Salt Lake City and smashed up the stock tank pretty badly. I bought a 45 gallon aftermarket replacement tank that bolted right in place of the stocker. It was designed so that it used up every cubic inch of space between the frame rails. The "extra" fuel capacity came mostly from making the tank wider and longer than the stocker, but it still fit into the space where the stock tank had been. The rear of the tank was angled upwards to improve the departure angles. I also ordered their optional skid plate, which was welded directly onto the bottom of the tank. The bottom of the tank only hung about 1.5 inches lower than the stock tank.
    Filling that thing up for the first time was painful. It took a long time and cost a lot of money, but I could do a LOT of driving before needing to fill it again! /forums/images/graemlins/cool.gif It was made by a company in California called Arrow Tanks, but they don't seem to exist, at least under that name, any longer. But it appears that Aero Tanks makes the same sort of stuff. I don't know if they had to change their name, chose to change their name, or are a completely different company, but you can check out their stuff at www.aerotanks.com /forums/images/graemlins/cool.gif
  6. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Wow! I'd like to see that 43 gallon tank under a K5. I have a 45 gallon tank under my Suburban and it occupies every bit of space between the frame rails and between the rear diff and bumper. It hangs down a good distance too, and a K5 obviously has less overhang than a Burb. /forums/images/graemlins/eek.gif
  7. Larry_in_Tx
    Larry_in_Tx 1/2 ton status
    Oct 24, 2002
    404
    Houston Tx.
    Here's mine hang'n under my '72. It's a 45 gallon tank that was on the truck when I bought it. I snapped the pic from this spot so you could see the angles Harry was talking about.
    I've been loving the extra gas in there since putting the 454 in the truck but it's always in the back of my mind out on the trail. No rocks down here in Houston so I haven't beat it to death yet.
  8. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Can't link from Webshots..
    Here ya go,
    John
  9. Larry_in_Tx
    Oct 24, 2002
    404
    Houston Tx.
    Thanks /forums/images/graemlins/thumb.gif I thought everything was ok because I could see it on my screen. I'll just stick my finger back in my nose and go hide somewhere.
  10. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Here is the one I had planned on going with: http://www.nwmp.com/ftcat.htm They have a 43 gallon replacement. The only thing I am miffed about is when I asked them about a skidplate built in, it would run an extra $100 or so to add. Rather pricey on top of the $450 price tag without the skid plate shipped.
  11. triger
    Jan 16, 2003
    177
    <font color="green">Yeah that is the same site I was on...I am putting a 3 inch body lift on the truck and was thinking I could shove the tank up as far as I can...Have to see...there's alot of other worthless purchases to be made before I worry about more gas...
    T </font>
  12. deek
    deek 1/2 ton status
    May 6, 2003
    142
    Great Bend, KS
    they sell them in JC whitney
  13. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    Its no biggie! /forums/images/graemlins/rotfl.gif
    John
  14. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    I have one in mine and it hangs about an 1 1/2"below the stock bumper. this will further be cured by the future 1" body lift. its great but filling it up sucks!!!!! its held up by 2 straps and has a drain plug that makes it easy to drop.
    nathan
  15. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Could you post some pics?
  16. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    why not just have an auxilary style tank? just pump that into the main one when its low. if its the right size, you could mount it between the frame rails above the rear axle.
  17. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    im away on military duty, but i will call my wife and see if sheel snap one for you.
    nathan
  18. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Come back safe, and hoist a cold frosty one on me. /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/thumb.gif
