could you use an AC condensor as a cooler?
Discussion in 'The Garage' started by jjlaughner, Jul 27, 2004.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I have an AC condensor thats still good and has the fittings... Could I use an oil cooler and some lines to make it an oil cooler or maybe a HUGE tranny cooler?
    I want to keep the AC thants in the blazer so could I stack a condensor plate, then a 2nd condensor plate (oil or tranny cooler) then a 3 or 4 core radiator up front?)
    /forums/images/graemlins/thinking.gif /forums/images/graemlins/ears.gif
  2. Dandwg
    Dandwg 1/2 ton status
    Feb 9, 2003
    190
    Turlock, California
    My buddy has his hooked up for a tranny cooler. He was actually bragging about it yesterday. I will see if I can get some pics for ya /forums/images/graemlins/thumb.gif
  3. gzzgfw
    gzzgfw 1/2 ton status
    Feb 26, 2003
    505
    Jeremiah, I've used one for years. On this purple truck I blew it out to ensure there were no blockages and then sprayed brake cleaner down into it and blew that out to clean it. So far so good. I'd say go for it. /forums/images/graemlins/thumb.gif
  4. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    I run one in my daily driver. No issues so far. I sprayed some trans kleen through it and air after that to make sure it was free of any debris and so on. It will up your capacity quite a bit as well. I figure they are about 8 times the size of a normal cooler. Two rows and as big as the radiator core and all aluminum. Go to a place that does ac work and they can get you barbed fittings that thread right onto the ac condenser for you transmission lines.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: could you use an AC condensor as a cooler? *DELETED*
    Post deleted by HarryH3
  6. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Don't use it as an oil cooler. You want the engine oil to get hot enough to burn off moisture, thin to the proper viscosity, etc. Running it too cool can cause acids to form in the oil that can etch away at the bearings. /forums/images/graemlins/eek.gif
    Good to know!
    Thanks, I'll get it cleaned up and cleaned out set it aside for when I do the body swap! /forums/images/graemlins/peace.gif
