Couple Axle Questions
Discussion in 'The Garage' started by tcoker79, May 8, 2006.
  1. tcoker79
    tcoker79 Registered Member
    Feb 16, 2006
    38
    Creedmoor, NC, USA
    Ok, I did a search and still didn't find quite the information I was looking for. I'm thinking about upgrading to 1-ton axles. What I need to know is what trucks I should be looking at that would be a direct bolt-in. My fabrication skills are kinda limited. Any help you guys could be would be greatly appreciated. Oh, my project is a 1978 Blazer with 400sb and 35" tires.
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    A 60 from any chevy SRW should be a direct swap. For the rear, you will need to find a 3/4 with a 14BFF. The 1-tons/CUCV's have a more narrow spring perch width by about 2" and will have to be moved.
  3. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    yep, thats about it. front 60 from any 1 ton 4x4 73-87 (SRW). rear 14ff from any 3/4 ton 73-87.
