Couple Cage ?'s
Discussion in 'The Garage' started by mudman2882, Feb 20, 2007.
  1. mudman2882
    mudman2882 1/2 ton status
    Aug 3, 2002
    144
    Lubbock, Tx
    First off. I have done a bunch of searching and reading.
    Where are you guys getting the foot plates for your cages. I am going to use them to sandwich the floor so I can tie the cage to the frame. DIY4x has some staked ones for $16 but would like to find some that are cheaper. Also do they need to be staked or will they be alright with the 4 bolts?
    Also, how are you tying your cage to the frame. I think going directly to the frame would be easier but in some places that may not be possible. Any insight and pictures would be very helpful.
    I am going to be doing this in a 91 K5. Would love to see some fully built cages to get some inspiration.
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    The stake puts most of the sheer force on the stake and off of the bolts.
    Mines on the outside so it won't help you much.
  3. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    DIYs are probably the best ones out there... if you don't need stakes, you might try your local steel supply place. One close to me sells simple 4" x 4" floor plates for less than a buck IIRC. They are pre-drilled for 4 bolts and 3/16" thick IIRC.
    j
  4. mudman2882
    Aug 3, 2002
    144
    Lubbock, Tx
    I understand the point of having the stake on the plate but is this really needed when you are sandwiching the floor between the plates and going to the frame?
  5. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
  6. mudman2882
    Aug 3, 2002
    144
    Lubbock, Tx
    Thanks for the link. Those look like quality stuff.
    Has anyone used these?
  7. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    i wouldnt use bushings. that will allow the cage to flex a little bit.
    ruffstuff has some really good stuff and they ship 3 day so it wont take long to get there
  8. mudman2882
    Aug 3, 2002
    144
    Lubbock, Tx
    I wasn't sure if they would flex that much. My main concern is to get the fram as stiff as possible. Anyone have any pics of either a cage directly to the frame or tied in with floor plates.
  9. RGV72BLAZER
    RGV72BLAZER 1/2 ton status
    Jan 23, 2006
    2,425
    Edinburg*San Bene*Online-The Real South Texas
    but from what i understood, a bushing is a good option for those running poly bushings throughout the drivetrain, etc. a hard mounted cage would be an option for those running hard mounted bodys, motors, trannys, t-cases, etc....well at least that's what i understood...
