couple more problems......dieseling after keys off & rear wheels leaning o
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by twenty_below0, Aug 25, 2002.
  1. twenty_below0
    twenty_below0 1/2 ton status
    May 16, 2001
    436
    Haines, Alaska ...u.s.
    I am going through everything before the long winter gets here and these are a few more problems, I just adjusted the valves again (the longer pushrod issue) and now she diesels when you turn the key off, not every time but when it's hot and been drove for a while then it will do it? Did my timing change with valve adjustment?
    also have a 12 bolt with 20,000 miles on it since rebuild with everything new, I put a set of spacers on it about 3 mo. ago 3,000 miles approx. and when I park the rear wheels lean out. No leaks but still worries me anyone else have this problem and should I remove them and sell um? THx guys/gals
  2. twenty_below0
    May 16, 2001
    436
    OK dieseling is retarded timing and got that fixed now the rear wheels leaning...not every time I stop but enough to see?? what to do
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    leaning out like this /--o--\
    or like this \--o--/
    grant
  4. twenty_below0
    May 16, 2001
    436
    like this /-0-\ but not quite as sharp out more suttle but you stand behind it and you can see them tillted a little?
  5. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Wheel spacers love to wear out wheel bearings. GM made the drive train to have an offset spacing for good reason. Don't know what at the moment, but it makes me sound smart. /forums/images/icons/laugh.gif
  6. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    hmm, what is the backspacing on your rims?
    it might be to much force. i would pull the spacers out and try that for a week or so. then if that dont help i wouldpull the shafts and check them an the bearings.
    grant
  7. twenty_below0
    May 16, 2001
    436
    I'm not sure the back spacing, there just a run of the mill set of Outlaw2's 15x10 that I bought from a Les Schwab, nothing special. I will pull the spacers this week hopefully I haven't damaged the bearings or axle's
  8. 4x4dreamer
    4x4dreamer 1/2 ton status
    Jul 8, 2002
    874
    St. Petersburg, FL
    I thought cars/trucks would diesel if you put too much oil in them...just a thought.
  9. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
    That sure seems bad to me if the camber is negative enough that you can see it. Even if the bearings are fine, you will wear the insides of the tires off pretty quickly. If the bearings are bad, they will chew up your axle shafts pretty quick, so you should check into it pretty soon. Is it possible that the axle housing is bent? Any chance that it's always been like this and you just recently noticed it?
  10. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Dieseling: Check your timing and your fuel
    Rear Wheel Camber: Sounds like your housing/axle tubes are bent or your rear axle bearings are shot. Check the bearings and axles shafts first (probably a good idea to replace the bearings anyway and check the axle shafts for wear where the bearings ride).
