Couple o' simple questions that I should know the answer to...
Discussion in 'The Garage' started by NerdBoy, Feb 26, 2004.
  1. NerdBoy
    NerdBoy 1/2 ton status
    Dec 24, 2002
    429
    Southern Illinois
    Couple o\' simple questions that I should know the answer to...
    I'm running a carbureted 350, Edelbrock Performer Carb, mild (similar to an RV cam) cam, and headers. About where should my ignition timing be set? I have it at 14 degrees, currently, and it seems to like it.
    Also, about where should I be setting the idle speed? It is an automatic w/A/C. I have it at about 1000 RPM, but I don't think that is right. Any help would be appreciated.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Re: Couple o\' simple questions that I should know the answer to...
    Idle speed without the ac on should be 600-700. Timing is dependent. Run as much as you can without pings in the motor. 4-6* BTDC is stock I think. I ran 8-12* with my carb.
    Harley
