couple of 14FF hub questions...
Discussion in 'The Garage' started by Thumper, Oct 23, 2003.
  1. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    OK, first the easy one:
    I cant find the torque for the nuts that hold the hub onto the spindle. I assume the inner one isnt as tight as the outer one, but does anyone have the numbers?
    Second the harder one:
    The article I was reading seemed to allude to the fact that there are two different hub setups on the 14FF. One type ends up with a narrower wheel track width, while the other has the wheel studs set out towards the end of the hub making for a wider track width. It sounds by the way its written that they are interchangeable... anyone know about these? Are they something a guy should be keeping his eyes open for in the junkyards? Will the wider one bring the rear wheels out to a width closer to the front width without using spacers? Are the second type maybe on vans that we could be snagging instead of the entire diff? Supposedly, the first type give a width of 63", and the other type is a 67" width. Is there any info out there that I have been sleeping through? /forums/images/graemlins/smile.gif
    Thanks!
    Mike
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Inner nut torque: Torque down to 50 ft.lbs. then back off 1/8 of a turn, outer as tight as you can get it.
    My 14 is out of a 2wd. suburban, matche's front D60 very close, not sure of width. /forums/images/graemlins/grin.gif
  3. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    I thought it was inner to 50lbs then back off a bit then torque it to 35lbs and torque the outer to 35lbs. Then again I didn't have the best of luck with my last 14B, so w /forums/images/graemlins/blush.gifho knows.
  4. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I know the outter much like the front outter I just torque the sheit out of it with a standard 1/2" ratchet, probably around 100ft-lbs with that short leverage
