couple of questions?
Discussion in 'The Garage' started by nicotine, Apr 14, 2004.
  1. nicotine
    nicotine 1/2 ton status
    Jan 11, 2004
    116
    first if i have excess tire wear on the outside edge what does that mean?
    second if when i turn right i can feel a vibration in the stearing wheel that feels like it is coming from the passenger side tire what does this mean?
    third how do i correct the stearing wheel position to center? all the help will be appreciated /forums/images/graemlins/peace.gif
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Chock the wheels, raise the front and set it on stands.
    Check the ball joints and wheel bearings.
    With the wheel off the ground grab the top and bottom and see if there is any movement. If there is check to be sure if it is bearings or joints.
    Be sure to inspect all of the steering and suspension.
    Once it is all repaired and tight you can center the wheel by adjusting the drag link.
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Yeah they make this special tool that is used to adjust the drag link you cant do it with pliers very easy(been there done that) I think you can get them at any auto parts store.
  4. ilikemud
    ilikemud 1/2 ton status
    May 22, 2003
    111
    The Farmhouse, NJ
    i can adjust my drag link by hand, if and or when you have it all apart use never-cease as long as the bolts are tight it wont go anywhere when u are done with adjustment... tires might be out of balance? good luck
