Couple of questions..
Discussion in 'The Garage' started by Confedneck, Aug 18, 2003.
  1. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    looking to do new exhaust on my k10 hopefully soon, but will the extended capacity oil filter fit with long tube headers?..also...is there any certification i should look for when buying aftermarket body panels?.. thanks all..
  2. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    The oil filter should fit with your headers, depending what brand you have. Also some oil filters are larger than others. The filter i have on there now i dont remember what brand it is but its alittle bigger than the high capacity i used to use. it does not rub or anything but i question how close it is for heat reasons. i dont want the engine oil getting too hot from the headers.
    not to sure about your body panel question, but i would assume factory gm panels to be the best?
