couple of quick easy question
Discussion in 'The Garage' started by epurdy2005, Jul 27, 2006.
  1. epurdy2005
    epurdy2005 Registered Member
    Jun 7, 2006
    34
    Marion,IN
    I got my tranny and transfter case back in.....i'm almost positive but the exhaust goes on top of the big bar the transfter case sits on correct?........another question.......the bolts that hold the big bar the transfter case sits on has these big spacers.......Do those spacers go on top of the bar (in between the frame and the big bar) or on the bottom of the bar (in between the bolt head and the bottom of the bar)
    One more......I noticed that my front drive shaft starts moving a little when i hit about 35-40....What does that mean? Its not in four wheel drive and the locks are on FREE
    Its an 1982 k5 blazer by the way.
    Thanks in advance....
  2. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    The spacers can go either way; I forget how they work (I mostly have older trucks) but I gather folks use them to space the t-case down to change driveshaft angles. I'm sure someone with a new truck will tell you how they went originally.
    The driveshaft will turn slowly from parasitic drag whilst in motion; this is normal.
    -- A
  3. epurdy2005
    Jun 7, 2006
    34
    Marion,IN
    i'm guessing since this truck has a 4 in. lift i should put the spacers between the frame and the big bar so it would be dropped a little more.
  4. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    The spacers went inside the frame rail then the washer and nut on top.... Sometimes when people have issues after lifting their rigs, the spacers are moved in beween the crossmember and the bottom of the frame rail to lower the transfer case...
