couple of quick engine and axle questions
Discussion in 'The Garage' started by mr.smartass, Sep 10, 2004.
  1. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    first of all how do you tell if an axle is a 14bff or a 14bsf (total newb here) how much should it be to get one of these regeared? next, the main cylinder in my 350 is damaged and i'm eventually going to have to either rebuild or purchase another engine, what do you guys suggest? i'd love to put a 454 in it but i don't really know... help me out /forums/images/graemlins/1zhelp.gif
  2. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    look at the wheels by the lug nuts. a full floater will have a hub that sticks out past the lug nuts with a flat flange on the end with a Circle of bolts
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    When you say main cylinder is damaged , do you mean the cylinder bore ? If its too deeply scored , it will be cheaper to get a new block to build , or a new engine . Typically you can generally only go .060 over on a small block to overbore for repair/rebuild . They can be sleeved , but only in rare engines , in rare show cars , would sleeving be viable as an option /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  4. 502
    502 1/2 ton status
    Sep 9, 2004
    179
    California usually
    Perhaps a visual aide may be helpful. /forums/images/graemlins/smile.gif
    Deciding on a rebuild of your motor or perhaps purchasing a crate motor is usually a function of your total engine budget. GM Performance crate motors are sometimes excellent alternatives to rebuilding. They start at about $1550.00 for a 350cid 290hp/326lb-ft torque. Figure out what you're willing to spend and go from there. /forums/images/graemlins/cool.gif
  5. mr.smartass
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    thanks fellas, especially for the pics, i'm a visual learner /forums/images/graemlins/grin.gif as far as crate engines any specific recommendations? no budget right now so spend away.
