couple of ?'s, help needed PLEASE !...turn signal lever and dash pod
Discussion in 'The Garage' started by big d, Oct 15, 2005.
  1. big d
    big d 1/2 ton status
    Oct 24, 2001
    1,236
    illinois
    was wondering how to get to the wiring pigtail from the turn signal wand in my 91'. i need to replace the turn signal wand in mine and i cant afford right now to get it done professionaly (layed off). also, i wanna retro fit an 80-ish dash pod into my 91 cuz the dash pod is broken. was wondering with the 80-sh electric/speedo cable combo, if it was possible ? and where and how to swap in the speedo electric wires ? will my tranny or t-case still have the location to thread the cable into ? :confused: :crazy: please bare with me and thanks for any and all help. :bow: ;) :wink1: :D
  2. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Well, not sure what you want to do with the turn signal shaft. To get the lever out of the switch, just grab and pull gently but firm. Just pops in and out. The switch at the base and behind it is another story. To get to the base where the shaft attaches, the wheel and lockplate assembly needs to be removed. Then you have access to the switch. To get the switch out is again not too fun. You need to disconnect the wiring harnass at the base of the steering column. It is a long flat connector. Then you feed that through a small passage in the column itself. After you unbolt the switch, you can remove the whole assembly from the column.
    About the cluster and transfer cases... If you dont have the money to fix it right now, then wait. The issues you are facing with all the retrofitting you are talking about is not going to be worth it at this time. I dont know excactly how the newer gauge cluster works, but it is driven off the VSS. No cable. In order to get a cable to work, you need a cable driven transfer case, NP208 or early NP241. You need the speedo cable, and the correct instrument cluster. You also probably have rear ABS which is also run off the VSS, so theres gonna be major problems there. If I absolutely needed to use a different model than the current unit I have, then I would fit a 89-91 electronic cluster and components into mine.
    I would just fix what you have with parts from a junkyard. Find out whats wrong with what youve got. Gonna be cheaper and easier that way.
  3. big d
    Oct 24, 2001
    1,236
    illinois
    i found a 89' cluster and have it right here now. it has the old electric plug-in style in the back, thats why im asking questions. itll be no problem convrting to that style with the parts i found, i think, but i gotta know where the harness that plugs into the speedo runs to and where, since the last chevy i delt with was a 79' and dint have this, lol.. thanks for yur help and suggestions so far. much appreciated. :bow: :D ;)
  4. big d
    Oct 24, 2001
    1,236
    illinois
  5. big d
    Oct 24, 2001
    1,236
    illinois
    ttt2
