Couple questions about the S10
Discussion in '1983-2005 S-Series models' started by SO77, Mar 11, 2002.
  1. SO77
    SO77 Newbie
    Mar 11, 2002
    I'm thinking about buying a truck mostly for work to haul stuff around with me. I'm debating between getting a full sized or an S10. I was wondering what is the bed length/width on a late 80's early 90's S10 pickup?
    I was also wondering what sort of weight can it haul and/or tow with say the 4.3 v6 engine?
    I sort of think I'll have to go with a full sized truck but I thought I'd ask everyone here in the S10 forum first before ruling out looking at an S10. Thanks to everyone that replies.
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    s-10's have a higher weight rating than most mini trucks (1500#). Most rangers are 1200#. I don't know the measurements of the bed off hand but if I get some extra time I'll measure it for you.
  3. Big_B_Murphy
    Big_B_Murphy 1/2 ton status
    Dec 28, 2001
    159
    New Stanton, PA
    The regular bed is 6'
    The long bed is 7' but it is somwhat rare.
    They are tough trucks, but depending on how large of a load you tow you might be better off with a full size. I believe the 4.3 trucks were rated to tow about 5000 and the 4cyl trucks about 2000.
    I had a 95 4cly 5 speed. Great truck, great gas mileage. Worked the crap out of it. Even towed about 4000 pounds once or twice. Wouldn't reccomend it for long distances.
    Good luck in your search.
  4. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    I've got the same setup as big b used to have and I hate the engine. Truck is nice, did good, my advice is this, if you buy an s series get the 4.3 don't even think twice the difference in gas milege isn't worth it, In the last 6 years that stupid 2.2 has put me in situations on the highway that I almost didn't get out of because of lack of power, passing, getting on etc. Also if you get a full size then I'd consider the power plant as well, the full size chevy's with the 4.3 aren't too bad but my parents 97 ford with the v6 is just flat weak, it will pull but it hates it.
    Also if your not brand specific, and need space you my look into dakotas they are ranked as a mid size pickup, not compact like s10's, rangers, imports, and not full size, to the best of my knowledge they are the only truck in that class. Never owned one or drove one but they do have a bit more space as far as I know
    just my .02
  5. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    I agree my 96 C-1500 has the 4.3 with a 5-speed tranny and I can lay down a rubber strip about 15 feet long at around 4500 rpm with 3.42 gears. I do have a flowmaster 3" single catback exhaust and a K&N filter but I figure at the most that would only be good for 10 extra hp maybe 15 if I'm lucky.
    The only thing I have ever done to the motor other than change oil was putting in the K&N air filter only cause I wanted to give it a try. It has 97,000 plus miles on it and it is the most dependible truck I have ever owned. It even still has the original plugs and wires, hey the say 100,000 miles before the first tune up and so far so good.
  6. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    Go for a 92 (maybe 91) or newer s-10. They have the multi-port fuel injection vortec 4.3's. These have 200 horse and are much more powerful than the previous throttle body 4.3's.
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, it's '92 for the Vortec. They came out with that just a few months after I bought my '91. /forums/images/icons/mad.gif
