Couple Quick Questions....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Impex, Jun 10, 2001.
  1. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    What size nut is on the rear output shaft on the NP205?(1-3/8 or 1-1/2 inch socket?)And should i use the thicker 90-140W in the Arizona summer heat or stick just with the 80-90W gear lube? Thanks guys youre awesome [​IMG]
  2. xtreme_wlr
    xtreme_wlr 1/2 ton status
    Mar 22, 2001
    103
    San Diego, CA
    Dont recall what size the nut is, sorry. Buy both to CYA. As for the gear oil, AZ heat and all, go for the thicker stuff. Which reminds me, I need to change mine soon :)
    78 Chevy 1 ton Stepside RockCrawler
    468 BB, SM465, NP205
    D60 front, GM 14Bolt w/ Detroit
    <A target="_blank" HREF=http://www.bowtiecrawler.com>http://www.bowtiecrawler.com</A>
  3. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I have no idea on the nut - I run 90W-140 in my diffs for the heat, and thanks for the reminder - I need to change mine too!
    I'm so poor I can't even pay attention [​IMG]
    <A target="_blank" HREF=http://pugsley.coloradok5.com>http://pugsley.coloradok5.com</A>
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    to all you in AZ... son i will be down there. i am moving stations from Pendleton in South Cali to Yuma. and i put that in the back of my head for when i get my truck running...
    "change gear oil" &lt;--- note to self
    1974 Chevy Blazer Cheyanne. lots of plans for it....
    but it is on 33's now, with saggy old springs. i am in so cali if ya got any parts for me.
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Hey Impex i'm pretty sure that nut is 1 1/8th. I've always just run 80 90 wt gear oil
    "My blazer may be slow, but it goes faster at higher speeds"
    Jim
