Cowel induction hood in FWheeler mag>>>???
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Burt4x4, Sep 27, 2001.
  1. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Hey gang did you see that hood in the mag? It's all steel!! sweet looking!
    Anyone have one?
    I like the part they say when going slow on the trail the heat can escape out the top. I got peerty warn out there this summer!!
    What about rain and water?? Does the cowel alow tons of water in right on top of the air cleaner and distributor???
    Looks tuff but is it realy worth the "Look"????
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  2. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Steve, don't forget that if the hood lets hot air out through the riser, it exhausts right into the cowl vents, which are the inlets for the Blazer's ventilation system. I think that'd make the driver even hotter. FWIW, I have ridden in a car that had its hood louvered and the passenger compartment was hotter in that car due to the hot air being drawn into the ventilation system (I'd also be leary of fuel and exhaust gases entering the passenger compartment through the ventilation system).
  3. Burt4x4
    6,854
    Hmmm, good point Stevo!!
    I wish I could hear a comment or two from an owner of one of thease hoods!! But your right the vents are right there!!
    Hmmmm, probly won't waist the $$ on "getting the look!"
    I'm more into function anyway and if I have to suck fumes then forget it!
    Thansk bro and QUACK QUACK!! 2 weeks from tomorrow is opening day out at Woodward Res. QUACK QUACK[​IMG]
  4. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    hey burt how would you feel if the ducks were the ones with the guns and shootin at you?? [​IMG] I think ya need to go wheelin instead and leave the poor ducks alone! [​IMG]
    [​IMG]<font color=blue>Donations accepted for the "Build Chaz's 1972 K5 fund"!!!</font color=blue> [​IMG]
  5. EricM
    EricM Registered Member
    Apr 14, 2001
    61
    Savage, MN
    Chaz88k5 I hope you are just joking. There are many sportsman here on this board who will take offense to your comments.
    Burt4x4 I live in Minnesota and the season for us starts tomarrow the 29th at noon. I will definatly be in the duck blind tomarrow. QUACK QUACK!!! Ha Ha. Although opener doesn't usually offer a lot of birds it will still be fun. I can't wait till those northern mallards come down in the later part of October. Yee haw.
  6. travis
    travis 1/2 ton status
    Nov 17, 2000
    173
    Panama City, FL
    FWIW, US Body sells fiberglass cowl induction hoods that come with the cowl closed. I guess you cut it open and put up mesh if you want. They are expensive as all hell anyway, but they do have other cool fiberglass (and steel) parts.
    Enjoy <a target="_blank" href=http://www.usbody.com/67-72%20chevrolet%20truck.htm>www.usbody.com/67-72%20chevrolet%20truck.htm</a>
    Travis
  7. Dave_S
    Dave_S Registered Member
    Apr 11, 2001
    56
    Portland, OR
    Goodmark Industries (<a target="_blank" href=http://www.goodmarkindustries.com/HomePage.html>http://www.goodmarkindustries.com/HomePage.html</a>) makes a steel cowl induction hood. It runs $450 plus shipping.
    Dave
  8. SilverJim
    SilverJim 1/2 ton status
    Sep 23, 2000
    105
    Evergreen
    Re: Cowl induction hood in FWheeler mag>>>???
    I bought my cowl induction hood from Goodmark. The shop that media blasted my stock hood used too much pressure or something and ruined it. I would rather have used the stock hood, but since it was ruined...now I've got plenty of room for that 20" tall air cleaner. (Not really, but there is a bunch of room.)
    1970 GMC Jimmy 502HO/SM465/NP205 doesn't run just yet!
  9. Dave_S
    Apr 11, 2001
    56
    Portland, OR
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    Ah... they probably blasted directly with the blaster. Big panels are real succeptable to deformation if you don't keep the angle of blasting shallow.
    Sad to hear it was on a stock bodypart:(
    Dave
  10. Burt4x4
    6,854
    Hey SilverJim, so how about the fumes gettin in the cab? Have you noticed any smells of fumes sence the install of your cowl?
    How about water gettin in? Has that been a problem for you yet?
    Burt
  11. SilverJim
    Sep 23, 2000
    105
    Evergreen
    As soon as my truck runs, I'll let you know. I'm working on the wiring harness right now and then I have to throw the axles under it. I'm guessing I have 30-40 hours to put in before it'll be drivable.
  12. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    I run the hood but used some thought and made it a real cowl induction hood, lowered the air inlet temp by 75 to 120 deg. when offroad not hard to do. No water gets into the intake when driving or parked. Fir is better than my 30 year old hood.
  13. Burt4x4
    6,854
    OK, so I must be missing something.
    Real cowl induction?
    I know nothing about thease hoods. I just assumed it's a hole at the back of the hood. That allows air in/out....
  14. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The cowl area is a area of high pressure so when driving air will be forced in through the cowl in the hood. On cars with factory cowl induction the air cleaner is sealed to the underside of the hood so that all the pressure in the cowl area gets into the motor
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  15. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    What did it take to do this? What air cleaner assy. are you using?
  16. Burt4x4
    6,854
    aaaaaa Ok like the Old RoadRunners !! Gotit!
    well pobly skip the hood idea for now..too much $$ for little added function!!
    Thanks fellas
  17. blazer72
    Apr 13, 2000
    939
    KCMO
    I run a TPI so I just inclosed the hood front to back between the stifeners and used a 4 inch rubber elbow that points the air intake strate up sandwhiched an airfilter in between the bottom of the hood and the inclosement. The hood as to be closed for it to work, when the hoos is open the airfilter is atill on the hood.
  18. travis
    Nov 17, 2000
    173
    Panama City, FL
    I just bought a fiberglass cowl induction hood from ebay. Brand new, $390 with shipping. I should get it put on in a few weeks. I'll let ya'll know how it turns out.
    Travis
  19. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Do you have to get weaker hood springs when you go to fiberglass? I thought I heard something like that sometime.
  20. travis
    Nov 17, 2000
    173
    Panama City, FL
    I haven't heard that yet. I guess it's better to find out now rather than the hard way later. I'll do some checking around before I put it on.
    Travis
