Cowl Induction hood ?????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by opfor2, Feb 12, 2003.
  1. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    I was thinking about replacing my stock hood with one of those "Cowl Induction" hoods from LMC. (pg 21, cat # bzc.11) My question is how well does induction cooling work and is it worth doing or should I save my $$$$$ for something else ?
    Dan....
  2. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    the actual cold air induction will not work at all if you use the stock air cleaner and snorkle on your 90'becaues it gets its air from the front.cowl induction is to get air into the motor for power,not to cool the engine.its mostly for looks. /forums/images/graemlins/k5.gif
  3. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    They are basically for looks, but it does have vent holes in the cowl, so there will be more air-flow in the engine compartment, it may help with some cooling....
    Mine is a Key-part..
  4. dyeager535
    26,976
    The cooling benefit is almost nill compared to a properly operating cooling system.
    If you plumb it up as ACTUAL cowl induction, it might be worth a few HP, but thats because there is pressure at the base of the windshield forcing air in when you are moving...heat won't escape there unless you are sitting still, air is forced in behind the cowl opening.
    Save your $$ for something like headers, probably the single most cost effective (to power gain) mod you can make.
