Cowl Induction hoods....
Discussion in 'The Garage' started by Silver84k5, Feb 2, 2003.
  1. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Does this do anything for performance or is it for looks? Is it more then just putting a cowl hood on? do i have to actually do something to the motor or what?
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Well, yes and no. It depends on how the hood is designed. The ones you see mainly for our trucks with the 2-4 inch raised section through the middle does nothing except for give your truck cool looks. They're designed to accomodate engines with a high-rise intake manifold, tall filter element, or sometimes a blower.
    Now, the ram-air hoods, where the hood is bumped up in the middle and there are openings facing towards the front of the vehicle - those do something. Those are for running an open filter element and they (like the name implies) ram outside, cool air into the engine compartment.
    I was thinking of getting a fiberglass cowl hood (the one I talked about first) cause I think they look cool and would like the lighter weight, but the cheapest I've found is $400, and it would still need painting.
  3. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    thx.....
  4. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    if it is channeled to the intake it will add power if its just opren the motore will run cooler.
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The cowl hoods can be done both ways. For looks, or for looks and function. When I get my next built motor (probably 406SBC) then I will most likely put on a cowl hood, but it will be functional. I like the look, but I want it to work too. My truck is about function more then look. A functional cowl hood will suck in cool air from right in front of your windshield where there is a dead space where air just sits.
  6. cybrfire
    Dec 15, 2002
    15,143
    579
    Iowa
    The air passing over the top of the cowl and then up the windshield creates a vaccum which pulls air in through the radiator and undercarriage up through the engine compartment right by the air intake and out through the cowl. If the hood is open to the cowl it will improve performance and lower under hood temperatures. They work best when the air cleaner is tall and up in the scoop to gather more air.
  7. 89K1500Chevy
    89K1500Chevy 1/2 ton status
    Nov 9, 2002
    645
    Georgia, Fayetteville
    i have one and when the stock clutch fan was on it would blow pinestraw off the windshield. now that i have ele. fans it sucks the pinestraw down under the hood so it does work and when the truck is parked you can see all the hot air rising out the hood. My under hood temps drop pretty fast i got an A&A powerline fiberglass with steele reinforcements for 500.00 that was dealer price cuz i ordered from Mikes trailer hitchs and acc. /forums/images/graemlins/deal.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/usaflag.gif www.zombieoffroading.8m.net
  8. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Ive seen a 3½ for $219 ill get the web site up here soon
  9. blownK10
    blownK10 Registered Member
    Jan 23, 2003
    8
    Southern CA, USA
    Ive got the cool factory one on my 70 Chevelle that has a little door that opens up at the base of the windshield when you stomp on it. Its actually hooked up to open when the secondaries open on the carb, it gives the engine alot more air. I thought id have to put one on my K10 for clearance when i installed the blower but with the body lift i had just enough room, just had to swap out the tall aircleaner with a normal sized one. I dont think it would do much performance wise unless you rigged it up like the Chevelle with the suction-cup aircleaner base and were able to route the fresh air directly into the carb. Anyhow my .02
  10. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Watch out for those cheap hoods. My friends dad got one for his Camaro and is sucked. It was thin metal, had flaws and would have bent if a bird landed on the car... /forums/images/graemlins/tongue.gif
  11. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    AHHH the air passes over the hood and hits the windshield this make high pressure point not a low one at the base of the windshield, An open cowl hold will raise the underhood temp at speed but will lower it on trails. They work best if only the air intake of the motor can breath though them. /forums/images/graemlins/k5.gif
  12. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
  13. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Thx for that website, i was mainly looking to get Fiberglass so as to cut weight and was just wondering if the cowl did anything, it looks cooler anyway, so i think im getting the one off that site, Thx a lot.
  14. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    glad I could help but I would be really glad if you could tell me how you like it when you get it I want the same one.
  15. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    will do, but dont hold your breath i need some stuff before the hood.... beadlocks, hydro, hysteer, sliders, winch bumper......................... fiber hood. Guess ill get back to ya in a few years /forums/images/graemlins/thumb.gif
  16. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    cowl hoods also were designed to allow air sucked in from the radiator to have a place to exhaust out. Dunno how it affects our trucks, but i know mustangs when they go over 100ish, their noses start to raise up, from the front air entering the engine bay, and exhausting out of the bottom of the car, pushing it up.
    A cowl hood fixes that by moving the air over the top of the car.
    Well, unless your lucky enough to have a Corvette (exhaust on the side) or a M3.
  17. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    well my truck cant go 100, itll go 60 down hill with a tail wind though /forums/images/graemlins/thumb.gif
