crack at t-case mount how to fix
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85blazer350, Jun 1, 2003.
  1. 85blazer350
    85blazer350 Registered Member
    Sep 5, 2001
    51
    Grande Prairie,Alberta,Canada
    when i pulled the t-case found a crck in frame wher the t-case cross member mounts it goes from the inside of the frame to the bolt hole and ends where the frame goes up. what would be the best way to fix this.
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    weld that sob
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Grind the crack into a V-shaped notch, weld it up, and add a plate for reinforcement.
    -- Mike
  4. dyeager535
    26,979
    No welding expert here, but I thought drilling out the end of the crack, since the hole has no sharp "edge" afterwards (same idea as shotpeening/smoothing connecting rods), is the preferred method when welding cracks?
    Like I said, I'm no expert, I know some of you on here are though /forums/images/graemlins/smile.gif
  5. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Yep, drill a hole at each end of the crack to stop it from going further. Notch the crack with a grinder, and weld it up. After welding the crack, grind it smooth with the frame.
    John
