crack in 700r4 housing
Discussion in 'The Garage' started by scrappyk5, Jun 9, 2003.
  1. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    i have a crack in my 700r4 bellhousing
    that starts at the middle bolt hole for the torque converter cover plate and goes up about 4". i need to try and repair
    without pulling the tranny. it would be too hard to try and
    weld , so i was thinking i could drill a small hole at the
    end of the crack to stop from cracking anymore , then use a small strip of aluminum with some jb weld and cover the
    place already cracked . what do you guys think ?
    will this work for now ?
    or do i need to pull and weld?
    also , what kind of weld wire would i need to
    weld it?
  2. dyeager535
    26,980
    Engine puts more stress on that bellhousing than JB weld could ever hope to hold.
    If the crack was from hitting a rock or something, then *maybe* something short of welding will work, but if its from stress, the JB weld won't work. Had a friend try that on a cracked extension housing and it didn't last 5 minutes.
  3. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Try using some cold weld. I know carquest carries it. It is stronger than jb weld.
    Dan
  4. scrappyk5
    Mar 17, 2002
    2,099
    virginia
    i will try the cold weld.
    i should still drill a hole at the end of
    crack right? i was told that will also help stop the crack from extending.
  5. dyeager535
    26,980
    All I've *ever* heard for crack repairs says that a drilled hole should be used to help prevent cracks from spreading.
  6. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    Check where the crack is and make sure it isnt into the front pump area. If you are fine then drill a small hole just bigger than the crack to prevent it from spreading.
    Dan /forums/images/graemlins/k5.gif
  7. scrappyk5
    Mar 17, 2002
    2,099
    virginia
    the crack is only a couple inches extending from the
    middle bolt hole for the inspection cover. the main thing
    i wanted to do was to stop the crack, then just put some stuff to fill in the crack area and maybe give it some
    hold. thanks guys.
