Crack in the Floor
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TXsizeK5, Dec 3, 2001.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Looking from the under side of the blazer there are 2 like "spider web" cracks in my floor.. is there something i can do to repair it or hold it to keep it from cracking more? Thanks..
    6in 87' K5 w/ 35" BFG muds.
    305/Sm465/ NP208
    Kn, 4.56's.
    In desperate need of a rebuild.
    Next- Eaton mech locker... Flows.
  2. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    when i repainted my 88 i pulled up the carpet and found the same problem...i just welded it all back together and reinforced around the bolt holes for the seats...as far as i can tell its fine now and its been about 2 years...
    <font color=green>Chaz</font color=green>
    [​IMG]<a target="_blank" href=http://community.webshots.com/user/chaz88k5>http://community.webshots.com/user/chaz88k5</a>[​IMG]
  3. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Loose some weight damn it, haha. I've only seen late model Blazers do this, I can't figure out, unless its just coincedence.
    <a target="_blank" href=http://new.wavlist.com/movies/031/ag-blow.wav>"I ain't nobody, dork."</a>
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    strengthen your frame up a bit by boxing it or by adding crossmembers and triangles to it. but weld up the cracks also.
    new bushings might help after the repair but i doubt it. and get a more flexible suspension. take the stress off your frame a tiny bit
    Grant
    1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I had those too. Can't weld them shut, you'll burn through the floor. I brazed them though.
    90K5
  6. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    I as thking bondo or jb weld lol.
    Oh well... what would be a more flexible suspension.. i have really stiff shocks now... RS5000, I was thinking of getting some other ones... and single shocks in the back isntead of 2 or something like that.. and some edelbrock shocks although they are very xpensive
    305/Sm465/ NP208
    Kn, 4.56's.
  7. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    First of all, you need to stop drill those cracks. Then you need to remove any loose rust with a wire wheel of some sort that will also take the paint away. Then you need to get a piece of 1/8 angle iron or something to that effect. Lay it down and mark your holes. Then drill the holes out so that your seat bolts wil go through the angle iron adn hold it straight and tight. Then you weld or get someone lese to weld that 1/8 angle iron to the floor where it is long enough to over lap the 2 under cab supports. then tack all the cracks up real good "without" burning through the floor.
    The part where you have hte most problem with burning through the floor is where you weld the thinner floor part to the 1/8 angles iron. If you can weld just make sure you have the wire pointing more into the thicker material piece than the thinner floor. And space the tacks out really good and allow ample time for the metal to cool. Then coat with some good undersoating that has rust suppression and sound proofing. They sell it at AutoZone. Then layout your insulation and then the carpet or floor mat, what ever you have. You will notice a hell of a difference in the stiffness of your seat. TRUST ME and I only way 170 lbs.
    Still hoping the GOV'T will ban the use of loud stereos with RAP music. [​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
