Cracked 12v Coil Twice In a Row
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 73k20, Jan 9, 2002.
  1. 73k20
    73k20 Registered Member
    Jul 6, 2001
    59
    South Louisiana
    Does anyone know what would cause a coil housing to crack? We put another one in and within a few minutes the same thing happened again.
    Who said size doesn't matter?
  2. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    Is it the kind that is in top of the cap or the external kind? Maybe the bracket is twisted and it is putting too much force on it. If there is too much voltage it could be super heating the oil inside and and the expansion of the heated oil is cracking the case. Do you have a balast resister installed between the batt terminal and the power source, if not you need to do so in MOST cases.
    John
    Like to go sloppin' 'round in da mud in a rapid fashion....=)
    <a target="_blank" href=http://coloradok5.com/gallery/albun31?&page=1>BLAZER PICS</a>
  3. 73k20
    Jul 6, 2001
    59
    South Louisiana
    Well, This is on my friends Toyota 4x4. He has the external type, but it's not the regular round canister type, The internal part is round but the external surrounding piece is square. This might be what is called an open coil. I'm not sure of the ballast resister.
  4. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    I know a square peg in a round hole doesn't work too good .... guess a round peg in a square hole doesn't either. Is it possible something else has shifted under the hood or been installed that might come into contacht with the housing while bouncing around?
  5. 73k20
    Jul 6, 2001
    59
    South Louisiana
    This actually happend while sitting in the driveway. He had some wiring problems last week and now we think that the tachometer wire was connected to the coil which means that the higher the motor reved the more current was being sent to the coil which turned out to be too much current/voltage.
  6. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Is it a stock GM coil (ie the newer TBI style)?
    GMs '75 and newer do NOT use a ballast resistor.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
