Cracked AA Bellhousing
Discussion in 'The Garage' started by rcamacho, Jan 18, 2007.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    The AA bellhousing cracked behind my BBC and NV4500. Anyone out there had success welding up the thick style cast aluminum bells or should I just spring for a new $345 unit?
    BTW, why the heck does no one make a steel scattershield for chevy to NV4500?
  2. tRustyK5
    Jul 23, 2000
    36,167
    1,364
    E-town baby!
    I've done some welding on cast aluminum and it is a real PITA. Depending on the shape, thickness and where the ribbing is (if any) determines whether or not the weld will hold or just spider web crack even worse. The cast aluminum is rigid and doesn't tolerate the rapid expansion and contraction of the welding very well.
    Rene
  3. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Stop-drill the crack(s) and then 'V' it deep. Then heat the whole thing up to almost too hot to touch while BOLTED to a spare block. SS wire brush (NOT carbon steel!) it clean & run a root pass. re pre-heat. Clean. Run a filler pass, re pre-heat, clean, etc. until done.
    Leave it bolted to the block until cool.
  4. rcamacho
    Jul 1, 2004
    1,324
    WA
    Thanks guys. I was able to strike a deal with AA and have a new housing on order. If anyone is interested in the old housing PM me - I'll have no use for it.
  5. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    Hijack Alert !!
    anyone ever had any sucess at welding up the output shaft end of a T-400 case where the transfer case adaptor bolts on ?
    I have a K case T-400 that has 1 small crack on the lower right side ( looking at the end of the opening )
    It would be a shame to throw out the case if it can be salvaged...
    Now back to your regularly scheduled thread.....
