Cracked block at starter mount?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blaze`, Nov 29, 2002.
  1. Blaze`
    Blaze` Registered Member
    Mar 12, 2002
    54
    Austin, TX
    Can anyone offer a suggestion on fixing a cracked block at the passenger side starter mount? It is causing my starter to loosen and eat my flywheel and starter gear. Any suggestions besides the obvious of replacing the block would be appreicated. Can you weld the crack? Would JB Weld work?
    Thanks in advance.
    donovan
    `73 K5 Blazer w/350 /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I have heard of people getting the block welded up. That might be an easy option.
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    That exact thing happened to me a couple months ago, even had a post about my problem. Yes you can get it welded up. I had mine welded up, and I also made myself a starter hold bracket for the tail end of the starter motor that bolts to the block.
  4. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    Had the same problem, got it welded up, with a lifetime guarantee. Cost me $200. Small price to pay when you think about the cost of a new block.
  5. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I got mine done for free, but then it helps to know people /forums/images/graemlins/grin.gif
  6. BlaznRebel
    BlaznRebel 1/2 ton status
    Sep 1, 2002
    115
    Louisiana,Baton Rouge
    WEld it and GM sells a starter brace for a SBC, it's like 7 dollars. The brace will keep the starter from torqing out, they are used primarily on high torque motors like deisels. I have a brand new one here if anyone wants it.
  7. Ck1500
    Ck1500 1/2 ton status
    Feb 8, 2001
    198
    Burton, Michigan
    i had mine happen in my 1988 Chevy PU and i dropped the starter and welded it up myself and installed the starter bracket for 14 bucks it was soooooooo worth it /forums/images/graemlins/smile.gif
    hope this helps
    Ck1500 /forums/images/graemlins/ears.gif
  8. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    Don't scrap it, JB it!! /forums/images/graemlins/grin.gif
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    most all SBC came with a rear mount brace since back in at least the late 60's ive got several ive saved off of old 307's and 350's and such form 67-72 years, but i just tossed em all out along with all kinds of old style engine mount trees and mounts and clutch linkages last week.
    good luck
