Cracked brake shoe
Discussion in 'The Garage' started by WhiteBurb, Nov 8, 2006.
  1. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    I was doing some maintenance over the weekend, rotating tires, inspecting brakes and such. Anyways, one of the brake shoes was cracked, the friction material. Everything seemed to be adjusted right.
    Any ideas on what might have caused this? I'm thinking they were just poorly made el cheapos.
  2. k5floyd
    k5floyd 1/2 ton status
    Feb 6, 2004
    313
    Friendswood, Tx
    i had this happen to me one time on one side with brand new shoes. cept mine did more then crack. they broke into a bunch of peices. had to turn the drum after it too. put they same brand in again and everything was fine. dunno what would cause it.
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Cracked brake linings are the result of overheated brakes.
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Yeah, what he said, very hot brakes,,,also i found out with my rear disk conversion, if you overheat those to the extreme, where they are crackling, ticking and smoking,,, when they cool down, it eats up the wheel seals :p: :D
  5. WhiteBurb
    Mar 10, 2005
    307
    Louisiana
    Overheated brakes? Maybe a bad cylinder? It doesn't seem like the brakes are grabbing at all. It might have a slight drag that I don't notice though.
  6. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Do you use your parking brake? If so, mabey it's starting to stick a little.
