Cracked D44 housing
Discussion in 'The Garage' started by AussieK5, Oct 19, 2006.
  1. AussieK5
    AussieK5 1/2 ton status
    Jun 17, 2001
    316
    A land girt by sea
    I'm looking some help regarding a cracked housing from my 79 thats getting a frame off resto ATM.
    One of the PO had hit something hard enough to crack the housing and has had it welded up. The housing also has a steel ring adjacent the cracked area.
    Check out the near failure on the axleshaft (the lower shaft is from my K20).
    Have any of you guys repaired then run a housing for any length of time?
    Is that steel ring factory? Its not on my K20 D44.
    Im a little hesistant to use this housing long term and even tough its a major PITA, I'll swap it with my K20 housing before is sold. I'm very worried a crack will propagate accross the case.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Man if it wasn't for shipping , any one of us could find you a housing . I know where more than a few sit .
  3. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Pretty ugly looking.
    You could get reasonable ship cost if you seperate the axle tubes from the center section and ship that way.
    All you can do if your short on cash is run it and see. If it starts to crack it'll be easy enough to get the axle back out and replace it.
  4. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    throw it away....
    Marv
  5. Cricket
    Nov 29, 2004
    8,224
    Colorado
    If Marv says toss it - you better toss it. :D
  6. AussieK5
    Jun 17, 2001
    316
    A land girt by sea
    Yep, you guys have confirmed the conclusion I should have come to myself last night.
    Its not the cost thats the issue, the downtime to sort it out will take me away from the K5 resto. Damn damn damn...........
  7. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Might be for the best, who knows what could have happened. Everything happens for a reason.
  8. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    I agree with Marv, it's an anchor...
    Rene
  9. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    I look at metal all day. It's scrap.
  10. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    to bad you so far away, ive got a housing you could have but i bet shipping would be a arm and a leg
  11. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    Have to agree with 79jimmy350, if shipping wasnt a pain I would have given you the dana 44 I had.
  12. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I'm going to take the opposite point on this. Were there an easy replacement housing available I'd do that. Given the location I'm thinking that's not so easy to find. I'd run it and keep an eye on it.
    For a true resto you'd want another as that one has been "modified", but for a driver the repair may be perfectly fine.
    Now if it's bent in any way, then it's junk. That it got bent in whatever cuased the need for the welding is highly probable. I'd do some hard looking & measuring of it first.
  13. AussieK5
    Jun 17, 2001
    316
    A land girt by sea
    Thanks for the offers guys, I really appreciate the generosity. Time not cost, is my biggest enemy at the moment as I'm trying to cram as much build time in as I can before while I'm still on leave.
    The housing checks out straight and did serve me for about 12 months before it was pulled and the true extent of the repair was exposed by sand blasting. I agree it could probably be run in a DD indefinately, but its also going to be adapted to a 3 link coil set-up and therefore may be a wasted effort. If I was sticking with leaf springs I would just slot it under and swap it out some time after the build shakedown.
    I am doing some hard looking and hard thinking as to my options. This cracked housing has been a catalyst for me to revise my build specs.....yet again :doah:
    Thanks again for the very generous offers guys. :thumb:
  14. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    Truss the crap outta it. Like a race housing.
