Cracked Floor
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zcarczar, Dec 19, 2002.
  1. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    My Floor is cracked pretty bad. Its right under the drivers side seat mounts. What do I have to do to fix it? /forums/images/graemlins/1zhelp.gif
  2. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    braze it up...tryin to weld it is almost a lost cause because the metal is so thin....unless you are really good with a mig i wouldent even try that route..
  3. zcarczar
    Feb 10, 2002
    2,495
    hmm, could I get some say .120 plate steel and use it sandwitch the cracks and weld em up?
  4. Chaz88K5
    2,979
    Stockton/Lodi CA
    well what i did...i dont know if its the correct way or the best way but it worked well for me...took a wire coat hanger and used that as brazeing rod...took a torch and sealed up all the cracks...all the cracks i fixed are still holding up fine but a few new ones showed up...i need to pull up the carpet and do it again...i dident use another sheet of steel either under it...but i am sure it wouldent hurt anything if ya did
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    If you can sandwich the area with some thick sheet metal it would be the best.
    When I was doing a frame of on my 73, the whole section was rusted out so instead of getting a replacement, I got a 0.120 plate and formed it with a couple of bends to make it stronger and welded the nuts from under from the original floor.
    Now I have a great thick bullet ptoof floor.
    /forums/images/graemlins/thumb.gif
