cracked floors
Discussion in 'The Garage' started by mechted, Nov 2, 2004.
  1. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    767
    Granbury, TX
    ok, question for you
    the floors of my 73 are cracked around the seat mounts... (a single minor 1.5" on pass, several longer ones on driver's side)
    so could i just drill the ends of the cracks and weld em shut? or should i just bit the bullet and buy whole new floors?
    eventually i will replaced the floors... this will be a temporary thing
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    you could either weld them up or make small patch panels to replace the cracked spots /forums/images/graemlins/thumb.gif
  3. BIG B.
    BIG B. Registered Member
    Mar 10, 2003
    48
    SAN DIEGO
    I had the same problem with my 87. I cleaned up the cracked area, and pounded it back to form. Then I welded the crack, and reinforced it with another piece of sheet metal which I formed to the area also. I did it about 8 months ago and it is still holding on strong. There is no sign of weaking, and it is sturdy as hell. Dont know if this helps, but it is what I did.
  4. mechted
    Oct 19, 2003
    767
    Granbury, TX
    ok, sounds like ill do that for now
    thanks guys /forums/images/graemlins/weld.gif
  5. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    with sheetmetal I don't think it would make a difference to drill the end of the crack before welding it. I would just weld it up and call it good.
